Re: Re: Re: backhoes
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Paul Fox on February 16, 2000 at 03:12:32 from (204.176.212.3):
In Reply to: Re: Re: backhoes posted by GEO on February 16, 2000 at 03:04:50:
Thats good advice, IF you plan to leave the hoe on the tractor most of the time. My Woods has a subframe of sorts that ties the lift arms and the toplink together. The weight of the hoe is not supported by the hydraulics but by the frame. It's worked real well for me.
The hoe that JD sells with their tractors (or at least did when I was shopping in 1988) has a subframe. Having mounted and dismounted one on a 970 a couple of times, I found it to be a pain to mount, and the subframe (which stays with the tractor) seriously reduces ground clearance for other operations.
I'm also not a big fan of using tractor hydraulics to run the hoe, both because it's slower and because I'm not at all sure cycling the trans/hydraulic fluid temperatures like a working a hoe hard does is a good idea.
Just my opinion, of course.
Post A Followup
: Re: Re: Re: Re: backhoes
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
