Re: Farmall A is a quitter
Posted by CNKS on July 29, 2007 at 11:06:53 from (204.249.178.32):
In Reply to: Farmall A is a quitter posted by prawnfarmer on July 28, 2007 at 20:44:49:
Red flags 1.you cleaned the tank, you may have some crud still floating around that restricts the outlet. Remove the gas cap, use a light, and you can see to poke a wire into the fuel outlet. 2. As to the carb, if you did not soak the carb in carb cleaner, preferably a couple of hours or even overnight, then blow out with compressed air, you could have loosend something, as with the tank, and have a partially plugged jet.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
