Re: Farmall A is a quitter
Posted by prawnfarmer on July 29, 2007 at 19:07:56 from (66.232.160.11):
In Reply to: Re: Farmall A is a quitter posted by CNKS on July 29, 2007 at 11:06:53:
Did soak the carb overnight. Fuel flows freely from disconnected fuel line and also the drain plug in the carb as the carb does get fuel. Changed needle and seat again this afternoon. Double checked float level @ 1-5/32 per the book and jets are open. Ran about 15 minutes and decided it was fixed and started down the road to my daughter's place - made it out of my barn lot almost to the road. Same story -it quit. Starts again and runs 5 seconds a couple attempts and then quits for good. There is still a super hot spark from the distributor when grounded to the block right after it dies. This is a 12 Volt converted system if that matters.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
