Re: Charging a battery backwards
Posted by Lanse on July 06, 2007 at 14:49:10 from (152.163.100.197):
In Reply to: Charging a battery backwards posted by marvin johnson on July 06, 2007 at 10:37:39:
Well, wiseguy, In my experience, you just totaled the battery, possibly the cables, and the starter.
I would start with a new battery-see if it works
NEVER TRY TO REVIVE A BATTERY IN THIS SITUATION
the plates could be messed up and the thing could explode
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
