Re: Charging a battery backwards
Posted by John T on July 06, 2007 at 19:48:00 from (66.244.83.147):
In Reply to: Re: Charging a battery backwards posted by Andy Martin on July 06, 2007 at 16:13:19:
Good post, Im a long retired electrical engineer although lead acid batteries and chemical energy storage and all that lead n lead sulphate n acid stuff is actually more chemical then electrical or mechanical engineering as you well know,,,,,,,,,,
Anywho, the reaction of the lead n acid and lead sulpahte only yields one polarity as far as I know and regardless how his battery got discharged, EITHER from a load or a load caused by hooking it up backwards to a charger, I still believe he has a chance of reviving it by a correct polarity charge. Of course, once a battery is completely shot it can NOT be revived or recharged so if thats the case then it may NOT be possible to revive it BUTTTTTTTTTTTTTTTT I still see no problem with giving it a try cuz I dont see the chances of it "blowing up" any greater then the chances of any battery blowing up from charging cuz after all, even charging a good battery causes expolsive gases which a spark could ignite.
Any thoughts??????
John T
Today's Featured Article - A Farmall Restoration Story - What's Been Done So Far - by Sean Brinston. This is a story of my first real tractor restoration. My name is Sean Brinston and I was 15 almost 16 at the time of this.My neighbour directly across the road who I had helped with hay all the time had this tractor sitiing at his house for what I thought was 6 years. Finally I got the money and courage to ask him. I phoned him and he said it was already sold, eight years ago! ... [Read Article]
