Re: model # and help with Gm one wire conversion
Posted by Bob on February 06, 2007 at 15:35:40 from (69.178.229.154):
In Reply to: Re: model # and help with Gm one wire conversion posted by teddy52food on February 06, 2007 at 06:35:26:
That works just fine. It prevents running the battery down through the alternator, if the switch is left on.
A resistor, lamp, or diode in the "switched excire" circuit is STILL a good idea, though, 'cause if there's ever a poor connection in the charging circuit, current will instead try to flow to the battery through the alternator's diode trio and voltage regulator, and your oil pressure switch.
This will NEVER be a problem on less something happens to the charging circuit, so you're PROABLY OK.
He's the details, if you care to follow the schematics.
