Re: model # and help with Gm one wire conversion
Posted by teddy52food on February 06, 2007 at 06:35:26 from (204.73.107.177):
In Reply to: model # and help with Gm one wire conversion posted by Don Benson on February 05, 2007 at 16:19:42:
Bob, I have an H that had been changed to 12 volt 3 wire alt. The exite curcuit is a live wire to an oil pressure switch then to the alt. It has no need for a diode. When the oil pressure closes the switch, the alt charges & when the engine is stopped, the switch opens so there is no drain. It does not involve the ign curcuit. What do you think of this setup?
