lube or oil for steering shaft bearing
Posted by Kevin Brooks on August 08, 2005 at 10:10:57 from (129.33.1.37):
I've cleaned up my steering shaft and gearbox area. Bought new pivot shaft oil seal, felt washer and retainer and now ready to re-install. What have people been using (successfully, that is) for a grease on the steering shaft bearing? Was thinking of good wheel bearing grease. Would that work?
tractor: '51 M
Post a Followup
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
