Re: 560 GAS WEAK SPARK POPPING AT CARB
Posted by JREX on July 24, 2005 at 13:57:07 from (24.198.210.178):
In Reply to: Re: 560 GAS WEAK SPARK POPPING AT CARB posted by P Backus on July 24, 2005 at 11:15:05:
We have replaced all the electricial,,points, rotor, etc. Plug wires good. P BACKUS- The firing order is correct, using the 13-36-24. We will try the TDC on #1. Curious about checking the timing. I have the I&T shop manual NO IH-25. We did not see a timing mark on the outside but it appears the timing marks are internal. Looks like we need to pull the timing gear cover to check? The missing tooth on the gear. Only way to correct would be replace the gear?. Primary ignition wire? Location? We do not have a wiring diagram.
Thanks
Post a Followup
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
