Re: 560 GAS WEAK SPARK POPPING AT CARB
Posted by P Backus on July 25, 2005 at 08:44:18 from (69.128.32.82):
In Reply to: Re: 560 GAS WEAK SPARK POPPING AT CARB posted by JREX on July 24, 2005 at 13:57:07:
Have you gotten it figured out yet? It looks like Hal has got you
covered. Yes the primary ignition wire is the 12v wire coming
from the ignition switch to the coil. Sometimes they can get a
bare spot somewhere and will ground out intertmittently. The
timng gear would require some disassembly to see it well, but I
would only start looking there if the distributor rotor timing or
the spark timing is way off "mysteriously". If it"s only off a couple
of degrees, then the timing gear is ok. If it is the gear, you have
to take the front cover off to pull the gear off and replace it. I"m
not sure where the timing mark is on this motor. I would check
the front pully first and then the flywheel. There may be a hole in
the bell housing to see the mark.
Paul
Post a Followup
Today's Featured Article - The Mud Daubers and the Old John Deere - by Jon Zehnder. I have a 1941, John Deere Model A tractor I have owned for about a year and a half. This is my first (in case my wife reads this, "FIRST") tractor and it has been a learning experience. After considerable advise and assistance from local tractor nuts and the forums of Yesterday�s Tractors, I had finally got it running pretty well. I have tuned it up, overhauled the carburetor, installed a borrowed, rebuilt magneto, installed a new Power-Trol, patched the radiator, installed new front wheels a ... [Read Article]
