Re: 560 GAS WEAK SPARK POPPING AT CARB
Posted by P Backus on July 24, 2005 at 11:15:05 from (69.128.32.82):
In Reply to: 560 GAS WEAK SPARK POPPING AT CARB posted by JREX on July 24, 2005 at 10:46:04:
You could have lost a tooth or two on the timing gear which
would throw off valve timing as well as distributor. Sometimes
they fail like that when you go to start it. Check distributor
timing and check to see that the rotor is pointing directly at the
no. 1 cap terminal when no.1 is at TDC on compression stroke.
If they aren"t, check into it further. Check plug wire routing for
correct firing order. Check for a grounded primary ignition wire.
Paul
Post a Followup
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
