'47 M water pump questions
Posted by Mediocre Mechanic on June 04, 2005 at 20:26:08 from (205.188.117.138):
I've read that water pumps rarely stop pumping totally, but that's what seems to have happened on my '47 M. It's been overheating and blowing hot fluid out the overflow tube, worse this year than last. I drained most of the radiator fluid and removed the thermostat housing and top radiator hose. (No thermostat, must have been removed by the previous owner.) If I refill the radiator enough so the water starts overflowing where the thermostat should be, then start the tractor for a few seconds, shouldn't the pump push water out the top of the thermostat hole? Mine doesn't. The driver and drive pin appear to be installed correctly. I put a new fan belt on last summer and it's adjusted to the correct tension. The fan is spinning good. Is my water pump bad, or am I missing something obvious, which is entirely possible... Thanks in advance. This is a great forum.
Post a Followup
