Re: 300U Info
Posted by Ibby on December 14, 2004 at 03:33:54 from (63.146.104.143):
In Reply to: 300U Info posted by B Watson on December 13, 2004 at 18:23:07:
It sounds like your PTO bands need asjustment. It's a ticklish thing that needs to be done exactly by the book to work right.
Manual steering is never going to be easier than power steering, but going with the correct pitman arm lengths would likely make it as easy as it can get. I wouldn't mix or match parts. Use the ones that were designed for that system. Longer arms on the axle would turn easier, but you would loose turning radius.
Post a Followup
Subject:
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
