Re: 300U Info
Posted by Unreserved dick on December 14, 2004 at 09:39:40 from (4.228.153.190):
In Reply to: Re: 300U Info posted by B Watson on December 14, 2004 at 06:57:59:
IH made the modification to the steering knuckle after serial #26457. It included lengthing the steering gear arms at the gear box from 8-1/2" to 11" which might have maintained the original turning radius while making the steering work easier (you'd have to do some calculations or maybe a test to confirm this). Keeping everything well greased and fluid in the gear box helps a lot for either setup. Glad to hear you got the manuals. I never could find the magic x marks for adjusting the PTO, either. I've fiddled with this adjustment quite a bit, and the best way I've found to do it is: - turn the engine off, - back the PTO brake band screw out until it isn't doing anything, - put the handle into the PTO-disengaged position, - tighten the drive band adjustment screw until you get to the point where you can't turn the PTO shaft by hand anymore - then back it off just a bit more than enough so that you can turn the shaft by hand again, - then tighten the brake adjustment band up until you can't turn the PTO shaft by hand, - turn the engine on and tighten the brake adjustment band up some more (shouldn't be much more) until the PTO shaft stops turning; I adjust at low idle, and double-check at high idle. Basic idea is to get the thing adjusted so that one band or the other, but not both, is gripping when the handle is at either extreme. Hope the above is helpful (it works for me). You want to be a bit careful doing this adjustment. If you get it to where both bands are gripping at the same time, they're going to wear out quickly (if you're lucky) or something is going to break (if you're not lucky). Good luck.
Home
| Forums
| Order Support
Today's Featured Article -
More Memories of a Field Service Engineer - by Brian Dye. Introduction: The author worked for one of the largest Ford tractor dealerships in England as a trouble-shooter on tractor engines, hydraulics and combine harvesters from 1963 to 1972. In 1972 he became a dealer manager and finally left the dealer net in 1975 to run his own electronic design and manufacturing company. [Editor] We live right in the middle of Norfolk. The dealership that I worked for sold Fordson Tractors from the 1920's and some of t
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
