300U Info
Posted by B Watson on December 13, 2004 at 18:23:07 from (216.168.110.155):
Week two working on the "new" 300U, previous owner was something of a butcher. I musta taken the carb off five times before I figured out that the gas tank had about a half a cup of sand in it, the strainer was broke off inside the tank and sand was intermittently plugging the fuel petcock. couldn't figure out why the lift arms would lower when I disengaged the pto, the knuckle head had the pto handle hitting the lift arm handle.
Here's what puzzles me, even when not engaged the pto shaft is spinning like mad, though I can spin it relatively freely whan the tractor is not running is this OK or is something out of adjustment?
one other quick one, the service manual refers to two lengths of pitman arms, one a little over 6" the other over 9" I suppose this could save me much grief restling with the steering wheel if I can't get power steer. Suppose I can find the long pitman arms easier than power steering system?
Thanks
Post a Followup
Subject:
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
