Re: F-20 magneto help ?
Posted by Dave on August 19, 2002 at 18:34:22 from (216.42.124.196):
In Reply to: F-20 magneto help ? posted by TL on August 19, 2002 at 17:52:01:
Look in the hole on the clutch housing [carb. side of motor] with a light.Have some one crank SLOWLY.Find DC stamped on flywheel,align that with the pin that you will also see.A compression gauge or somebodys thumb in the #1 cylinder will verify compression stroke aproaching DC. Once you have that couple up the mag,set full retard [points housing C.C.W.] With impulse locked out,turn coupling till points open just a "hair".Find holes that are aligned and bolt it up.Should run fine.
Post A Followup
: Re: Re: F-20 magneto help ?
Today's Featured Article - Product Review: Storm Covers - by Staff. We recently had a chance to try out the new Storm Cover for the Ford 9N, 2N and 8N tractor that is now being re-introduced to a new generation of Ford N-Series tractor owners. Originally produced more than 40 years ago, it is now enjoying a reproduction run that has been licensed by the Ford Motor Company. An original storm cover was used for the pattern, and this reproduction cover is indeed exactly as the original (of which we had previously only seen pictures of in miscellaneous old sale ... [Read Article]
Latest Ad: Looking for a minneapolis moline zts [More Ads]
