Re: 450 engine miss
Posted by georgeky on May 14, 2007 at 09:55:01 from (205.188.116.138):
In Reply to: 450 engine miss posted by chester5731 on May 14, 2007 at 09:34:49:
Have you adjusted the valves? Try that. Maybe the timing is off a little. Sometimes new plugs are no good as well. The rims on your tractor are not mounted properly is the biggest reason for wobble. Run one wheel up on a 4x4 raising the other off the ground and turn a little then turn loose and the heavy side will be on the bottom. These can be a pain to get centered. It may take several adjustments to get them right. It also helps to balance the tires as best you can. There is also an easy steer wedge that can be added that will help some. I don't have one, but someone here on the board has a picture of one.
