Re: 450 engine miss
Posted by Adam H. on May 14, 2007 at 09:48:53 from (199.144.172.43):
In Reply to: 450 engine miss posted by chester5731 on May 14, 2007 at 09:34:49:
I would think a burnt intake valve is possible, but before replacing the valve take the valve cover off and check the valve stem, spring, rocker arm and pushrod. The valve spring could be broken or worn that when it is running it can't shut fast enough, or that the valve is just sticking a little. You can also check the valve clearance between the valve and the Rocker arm. If the valve seems to be sticking try a fresh oil change and add some Marvel Mystery oil to the crank case and run it for a while under load.
If all of that fails, then pull the head off and look for a burnt valve. Hope that helps.
