Re: Farmall 300 idle problem
Posted by IHpuller on January 09, 2002 at 13:00:50 from (12.30.224.53):
In Reply to: Farmall 300 idle problem posted by batman on January 09, 2002 at 10:06:16:
id check your manifold carb gasket and your manifold gasket. take some penetrate such as pb blaster and spray it all around where the gaskets are. if you have a leak the penetrate will momentarily plug the hole and the enginge shuld rev up slightly. try that and post back.
derek
Post A Followup
: Re: Re: Farmall 300 idle problem
