Tractor Talk Discussion Forum
601 workmaster fuel shutoff
walt delong
04-27-2008 18:24:18
i am tired of removing the gas tamk to replace the leaky fuel line shutoff on the bottom of the tank. how can i replace this two screw unit with some sort of elboe fitting and then put a filter and shutoff in a more convenient place? thanks walt
Les va.
04-27-2008 20:52:06
 Re: 601 workmaster fuel shutoff in reply to walt delong, 04-27-2008 18:24:18
Just take the old one off,remove the cut off screw comp.drill it out to the correct size and tap it out for a 1/8" or 1/4/" pipe plug.(I forget what size it is),then put your cut off down in the line somewhere else,I have fixed many of them and had good luck.
john in la
04-27-2008 19:14:45
We feel your pain. Those replacment valves do not last.
1) while you have it off replace the 2 screws with ones that have regular wrench heads on them. This makes it much eaiser to get the valve loose with a 1/4" ratchet and socket the next time. You do not need to remove the tank to get the valve off under these conditions.
2) do not replace your old valve; rebuild it. It cost less and last much longer.
I will give you a link to one post that tells you how. If you come over to the Ford Board of this site and do a search of this subject you will find many more.
walt delong
04-28-2008 20:56:26
 Re: 601 workmaster fuel shutoff in reply to john in la, 04-27-2008 19:14:45
thanks for the help on the shutoff for the 601
