Tractor Transporting Discussion Forum
Yet another question?????????
john in la
09-27-2007 20:28:13
Dave;
Let me not only open a new can of worms; but lets dump them out on the ground and watch them crawl.
Lets use Dick L as a example. He has a 1 ton and a trailer that weighs over 10,000 lbs when loaded. He buys and sells tractors on the side. He wants to have everything correct so he gets a DOT # and thinks he is fine to go. The problem is he did not plan on coming into Indiana when he bought his truck plate.
He comes across a deal to buy a tractor in Indiana for a good price. He plans on buying it and reselling for a profit. He drives into Indiana to pick up the tractor.
Is he in violation because he did not buy a temporary Indiana permit because he does not have Indiana listed on his registration as a apportion state; Or is his Ohio plate good in Indiana?????
davediehl@hotmail.com
09-28-2007 07:56:17
 Re: Yet another question????????? in reply to john in la, 09-27-2007 20:28:13
If your truck has a Gross Vehicle Weight (GVW) of 26,000 pounds or greater, it is an IRP qualified vehicle. If your truck has three (3) or more axles regardless of weight, it is also IRP qualified. If you leave the State of Ohio with your vehicle, you should have either an IRP plate or a Trip Permit. A Trip Permit is secured before entering another state for each state you travel through.
Germ
09-28-2007 08:24:30
 Re: Yet another question????????? in reply to davediehl@hotmail.com, 09-28-2007 07:56:17
Dave, thanks for all of your time and effort to help us out. As the others have said, the regs are confusing as written and open to interpretation. I guess we all feel uneasy without black and white readable and understandable regulations. That said, I think all of us want to be legal, and your help is truly appreciated.
My set ups, which I believe all need DOT numbers -1 tons 12,000 GVW up to 16,000 GVW and trailers from 7,000 GVW up to 10,000 GVW. Trucks all plated for 22,000 to 26,000, state of Ohio. We have fire extinguishers, triangles, and spare fuses in each truck and all of the trailers except for 1 flat bed. All of our work (contracting) is in Ohio (intrastate).
My questions -
Do we need medical cards?
Do we need to number each truck? Trailer?
Do we need to have all vehicles DOT inspected? I have been told we need this on a yearly basis.
If I go to the Portland, IN tractor show, can I take one of my company trucks for the weekend in case I find parts I would like to buy? I've avoided taking my truck in the past just because I wasn't clear on this.
09-28-2007 18:30:03
 Re: Yet another question????????? in reply to Germ, 09-28-2007 08:24:30
Once your compliant for interstate transportation, you can travel to Indiana without a problem using your company truck. Each vehicle requiring numbers would need to have numbers on the side using block letters.
09-28-2007 18:28:07
I typed in a link to the DOT site. Since I am not in your state, I don't want to quote laws that may or may not pertain to you. If you leave your state, and you qualify using the link, you will need to be fully compliant. If you go over 26,000 than you will fall under the CDL rules and regulations as well. Medicals, cab cards, logs, everything. Someone asked about Uhauls a few days ago, they have DOT numbers on each vehicle where required.
john_bud
09-28-2007 05:46:19
How big is that spoon you are using to stir up the ....?
Apportionment ! Yikes ! I don't even want to know!
jb
john in la
09-28-2007 06:55:36
 Re: Yet another question????????? in reply to john_bud, 09-28-2007 05:46:19
I "THINK" the cut off for the IRP plate is the same as the CDL; 26,000 lbs; but figured I would ask.
