Tool Talk Discussion Forum
So, would it replace a 1/4 air ratchet?
Eddie in MI
03-29-2008 13:23:02
Would you find it easier to use under the hood or dash of a car than a 1/4" air ratchet? Or is it a little gimmicky for that?
jack12345
03-29-2008 20:29:48
 Re: So, would it replace a 1/4 air ratchet? in reply to Eddie in MI, 03-29-2008 13:23:02
Its about the size and weight of my 3/8 drive air ratchet. used it about 2hrs today on 1/4 & 5/16 head sheet metal screws.If the nut/screw is too tight use it as a a normal ratchet until its loose for power ratchet to take over. I don't think it will replace your air ratchet but its really great not having that air hose getting in your way in tight places.Its 7.2 v takes more than a hour to charge.Used it to change out spark plugs ..have one that is rather slow to take out with std ratchet the Skil power ratchet took zipped it right out.Check out Amazon.com they have several reports on the Skil 2372.
