Tool Talk Discussion Forum
That should read penetrant 8(
ScottyHOMEy
03-07-2008 21:08:34
Sorry.
Bob
03-07-2008 21:31:44
 Re: That should read penetrant 8( in reply to ScottyHOMEy, 03-07-2008 21:08:34
I think you have FOUND your problem. The seized tensioner arm is causing the bolt to slip/squeal 'cause it's not keeping it tight.
Replace the tensioner.
ScottyHOMEy
03-07-2008 21:44:54
 Re: That should read penetrant 8( in reply to Bob, 03-07-2008 21:31:44
Yep. Got that part. What I'm lookin for now is fer ideas on how to break that stuck tensioner loose.
I've got a new belt to put on ( my cursory exaination of the whle situation indicates the old one NEEDS replacin' in the worst kind of way). But tuenin' the wrong way on the tensioner loosens the blt. Comin' back the right way, she pops back in but too much more effort and I'll twist off the bolt. Clearences are tight enough that it's hard to see where to put any heat that might help. For the meantime, I'll ppu the PB to her and run her, hopi' that the heatin' and coolin of he part will help loosen things up. I just don't have much fatih in that workin' on pot metal, and wonder if there's a better penetrant for the job.
Better yet would be a Ford tech willin' to share the trick for gettin' her loose.
alg
03-08-2008 03:07:46
 Re: That should read penetrant 8( in reply to ScottyHOMEy, 03-07-2008 21:44:54
Remove it from the block,don't worry about freeing it up.
