Tool Talk Discussion Forum
You are getting silly
jdemaris
01-24-2008 07:24:09
Well - perhaps we're speaking different languages.
Let me try to address your comments point by point. You are misquoting me - but I won't do the same to you. If you were claiming I'd said certain things - it would be hard for me to disprove. But . . . this is all here in writing. There is little substance to any of your claims.
You wrote "First off you were quoting average road fuel prices (with tax) for propane."
No, I was not. Where on earth do you get this stuff? Today - the homeowner's price for propane in bulk for household heat is $2.59 per gallon here in New York. NO highway tax. At my place in Northern Michigan it is $2.50 for "new customers" and $2.70 for existing customers. Not highway - just for heat. I called my son last night in Colorado, and he is paying $2.43 for propane to heat his house.
Your second point - i.e.
"you claim an advantage of gas/diesel over propane is that water vapor freezes at the regulator, but fail to mention/realize that water doesn't do much good for a gas or diesel engine either."
Yes, I did not mention the problems or contaminants in gas or diesel since it was already mentioned by someone previous to me. I was responding to the claim that propane was free of those issues that gas has. It is not. Propane bulk storage tanks can get moisture in them just as gas and diesel tanks do. I have had to thaw many LP systems and add ethanol to prevent future freeze-ups. Why do you suppose major propane suppliers sell and carry ethanol injectors?
Your third comment:
"You go on and on about the lower BTUs with propane but fail to realize its still cheaper to use 20% more propane than it is to use gas or diesel at current prices. "
I did not fail to realize anything. You keep failing to read carefully.
At today's prices - here in New York, also in Michigan - this is the actual cost to make the same power with equal sized gensets with the various fuels. Why don't you tell me more about my errors. Use facts please. And, let me repeat for those that can't read well - this all can vary depending on what YOU pay for fuel in your area.
Here in New York - today:
Household Propane makes 10,500 watts at a cost of $6.73 per hour.
Gasoline makes 10,800 watts at a cost of $5.66 per hour.
Off-road diesel makes 11,200 watts at a cost of $3.70 per hour.
Highway taxed diesel makes 11,20 watts at a cost of $4.53 per hour.
More details:
12,000 watt propane can make 10,500 watts for 38.5 hours on a 100 gallon tank. (Coleman)
At $2.59 per gallon that costs $259 to run 38.5 hours, thus $6.73 per hour.
12,000 watt gasoline can make 10,800 watts for 58.8 hours on a 100 gallon tank. (Winco)
At $3.33 per gallon that cost $333 to run 58.8 hours, thus $5.66 per hour.
12,000 watt diesel can make 11,200 watts for 83 hours on a 100 gallon tank. (Kubota diesel)
Farm fuel at $3.07 per gallon that costs $307 to run 83 hours, thus $3.70 per hour.
Highway diesel at $3.76 per gallon costs $376 to run 83 hours, thus $4.53 per hour.
Your next comment:
"On top of that a diesel engine will cost much more up front than a gas or propane powered unit that gains you little even if you use your 150 hours a year total. "
Well, your have a faulty premise to start with - i.e. your comment "gains you little."
Also about cost. Cost is not just what you pay up front, it how long the unit lasts and how much fuel it uses doing so. There are many good deals to be found with extremely HD diesel gensets at a low price when bought used or reconditioned.
Now, this IS an antique tractor site - correct? So, I'll assume that at least some people here have some mechanical aptitude. Perhaps you are lacking in this department.
I have a Delco diesel 12 KW genset I bought for $1400. I've had it five years now and used it a lot. It has a Detroit Diesel and runs at 1300 RPM. All parts are available cheap (engine and gen) and it's easy to work on. Same units are available "factory reconditioned" right now for $3000. You can easily go to Home Depot and pay close to $3000 for a gas-powered Guardian standby unit at 10,000 watts for $2600.
I can buy, right now, a brand new, Chinese Diesel water-cooler, 1800 RPM 12KW genset for $3800. These units are installed and used all over the world.
A Coleman 10KW gas genset with a Honda engine costs $3100 and has a limited 5 year/1500 hour warranty.
A Kohler LP and NG 12KW genset costs $3300 with a 3 year limited warranty. Engine is GC CH740 that runs at 3600 RPM.
A Norpro diesel 12.5 KW genset costs $7400 with a Yanmar engine. Has a 5 year, 5000 hour warranty.
The Chinese Diesel 12 KW genset costs $3800. Has a water-cooled 1800 RPM engine. Some places sell it with a 1 year unlimited hour warranty, and some with a 6 month unlimited hour warranty. Many of these units have been documented to run 50,000 hours without a teardown.
Now - in regard to your last comment towards me:
"If you don't want details don't ask for them."
Yes, I do want accurate details and I am open-minded. I'm also a more careful reader than you, and apparently better informed.
