Tool Talk Discussion Forum
Generator buying advice
tractormarkb
01-22-2008 06:06:00
I need a Generator with a budget of around a thousand dollars. I live off grid, I will use it about twice a week for about 3 hrs/week.
It will be stored in a shed outside, I live in Michigan-it gets cold here. I require electric start as my Wife will be starting it at times. I guess my biggest worry is cold starting. will Diesel fuel jell up outside? Does Propane start better even with a choke when its cold. Im afraid of how high gasoline prices will go up. also I have found many with no name engines probally chinese, has anyone tried one of these.
Ive had 2 small Briggs engines blow up on me this winter, time to try something different.
Require between 5-10 kwatt. Noise is also an issue.
tractormarkb
01-25-2008 05:32:25
 Re: Generator buying advice in reply to tractormarkb, 01-22-2008 06:06:00
Thank you all for your help. I can see that I'll have to increase my budget some to get a decent Generator. As usual your input is helful and interesting. Thank you!
old timer in ohio
01-25-2008 00:06:35
Hey there tractormark;
While these guys argue about which is best,
gas,diesei or propane etc.Why don't you get a catalog from www.northerntool.com,they have,
a selection of (I think)over 100.They have
gas,diesel,propane,And natuaral gas.The even have some that start automatically,to test their self. Bob
God Bless
the Unforgiven
01-23-2008 05:41:43
Up your budget a little and go Honda, Generac or Onan, all very good. And I will argue that propane is "very" inefficient, it is true that it does not have as much energy as gasoline but not by much. It will never gel in the cold or gum up your carb from sitting, and if you run continuous instead of seasonally you can double the hours on your oil. Many lp's do not have a choke, only a primer button, they will start as good or better than gas or Diesel, and if they don't there is something wrong with it. I have a 9hp Briggs 5kw on lp that starts on the third pull hot or cold.
jdemaris
01-23-2008 07:14:51
 Re: Generator buying advice in reply to the Unforgiven, 01-23-2008 05:41:43
Not by much? What exactly does that mean?
This all depends on prices in particular areas - but here are some averages. I've got no argument that propane - overall -is a good deal for some people, but certainly not all. If used to power a generator - it will make the least amount of electricity per dollar of all the popular fuels. For a stand-by genset, this is a minor thing. But for someone that has to run the genset for many hours every week, it's NOT a minor thing.
The average internal-combustion engine loses 10% efficiency when run on propane instead of gasoline (as reported by SAE testing). And, on top of that - a gallon of propane has less BTU energy than a gallon of gasoline or diesel.
Propane has an average of 87K BTUs per gallon.
Gasoline has an average of 125K BTUs per gallon.
Diesel has an average of 139K BTUs per gallon.
Today the average national fuel prices are:
Propane - $2.75 per gallon
Gasoline - $3.10 per gallon
Diesel - $3.32 per gallon
Off-road diesel - $2.90 per gallon
That means that - Propane - one dollar buys 31,600 BTUs
Gasoline - one dollar buys 40,300 BTUs
Pump diesel - one dollar buys 41,900 BTUs
Off-road diesel - one dollar buys 47,900 BTUs
This also means that actual use of propane making power due to the 10% drop in engine efficiency as reported by several SAE test shows:
Propane - one dollar buys 28,500 useable BTUs
Gasoline - one dollar buys 40,300 of useable BTUs
In regard to propane units being easier starting - that's a mostly YES and a sometimes NO. Propane does not gum, but certainly can freeze - usually due to water vapor in fuel freezing at the regulator. Vapor systems can be prone to this unless the propane tanks are maintained properly.
I've had to thaw out many. Propane is certainly convenient for auto-start units and also works well with households that already happen to have a large propane storage tank.
dhermesc
01-23-2008 07:53:12
 Re: Generator buying advice in reply to jdemaris, 01-23-2008 07:14:51
Is that propane the road price? I just filled the bulk tank with propane for $1.75. I seriously doubt my vender is selling below the average.
The other thing to consider is the fact he's running this a couple hours per year - its not like he's running an irrigation system. His biggest issue is going to be gummed up carbs - not the actual cost of running the generator.
jdemaris
01-23-2008 08:24:49
 Re: Generator buying advice in reply to dhermesc, 01-23-2008 07:53:12
Propane bulk-price today here in central New York is $2.69 per gallon. That's what it costs if I want to get my 1000 gallon tank filled. For smaller tanks, it's $2.75 - $2.85 per gallon. Some New England states are even higher at over $3 per gallon.
The national average today - for propane is $2.60 retail and $1.60 wholesale. So, from what you report paying, you are paying just a little over the average national wholesale price.
In regard to "The other thing to consider" that you mentioned - I already made reference to those things in what I already posted. Read what I already wrote.
dhermesc
01-23-2008 14:59:03
 Re: Generator buying advice in reply to jdemaris, 01-23-2008 08:24:49
I read your post, I was correcting your errors.
jdemaris
01-23-2008 17:07:13
 Re: Generator buying advice in reply to dhermesc, 01-23-2008 14:59:03
That sounds like a cop-out to me. What specific errors (of mine) did you attempt to correct?
Please tell me what exactly I wrote that you have shown to be in error.
It seems you are the one making a few blunders.
You wrote - "The other thing to consider is the fact he's running this a couple hours per year."
I assume you are referring to the opening subject of this thread? The poster (tractormarkb) started this thread with -
"I live off grid, I will use it about twice a week for about 3 hrs/week. "
Where I come from, three hours a week is much different than your "couple hours per year."
Seems it is closer to 156 hours per year.
dhermesc
01-24-2008 06:07:24
 Re: Generator buying advice in reply to jdemaris, 01-23-2008 17:07:13
First off you were quoting average road fuel prices (with tax) for propane. Then you claim the propane price is actually what you paid at your last fill up - not the national average. I don't really care because you'll probably make it up again. The average home owner has access to nontaxed propane but will not have access to off road fuel.
Second you claim an advantage of gas/diesel over propane is that water vapor freezes at the regulator, but fail to mention/realize that water doesn't do much good for a gas or diesel engine either. After 40 years of dealing with fuel systems both gas and diesel I have yet to encounter a frozen propane regulator (batch dryers, tractors, home furnaces) but have cursed and serviced several gas and diesel systems/engines infected with water (could it be the underground tanks?). Heads up - water is bad in all fuel systems - especially at freezing temps.
You go on and on about the lower BTUs with propane but fail to realize its still cheaper to use 20% more propane than it is to use gas or diesel at current prices.
On top of that a diesel engine will cost much more up front than a gas or propane powered unit that gains you little even if you use your 150 hours a year total. In 20 years you'll only have 3000 hours - well within the wear cycle of a propane engine. After 20 years - who really cares? You'll be lucky to buy parts for either.
If you don't want details don't ask for them.
jdemaris
01-24-2008 07:24:09
 You are getting silly in reply to dhermesc, 01-24-2008 06:07:24
Well - perhaps we're speaking different languages.
Let me try to address your comments point by point. You are misquoting me - but I won't do the same to you. If you were claiming I'd said certain things - it would be hard for me to disprove. But . . . this is all here in writing. There is little substance to any of your claims.
You wrote "First off you were quoting average road fuel prices (with tax) for propane."
No, I was not. Where on earth do you get this stuff? Today - the homeowner's price for propane in bulk for household heat is $2.59 per gallon here in New York. NO highway tax. At my place in Northern Michigan it is $2.50 for "new customers" and $2.70 for existing customers. Not highway - just for heat. I called my son last night in Colorado, and he is paying $2.43 for propane to heat his house.
Your second point - i.e.
"you claim an advantage of gas/diesel over propane is that water vapor freezes at the regulator, but fail to mention/realize that water doesn't do much good for a gas or diesel engine either."
Yes, I did not mention the problems or contaminants in gas or diesel since it was already mentioned by someone previous to me. I was responding to the claim that propane was free of those issues that gas has. It is not. Propane bulk storage tanks can get moisture in them just as gas and diesel tanks do. I have had to thaw many LP systems and add ethanol to prevent future freeze-ups. Why do you suppose major propane suppliers sell and carry ethanol injectors?
Your third comment:
"You go on and on about the lower BTUs with propane but fail to realize its still cheaper to use 20% more propane than it is to use gas or diesel at current prices. "
I did not fail to realize anything. You keep failing to read carefully.
At today's prices - here in New York, also in Michigan - this is the actual cost to make the same power with equal sized gensets with the various fuels. Why don't you tell me more about my errors. Use facts please. And, let me repeat for those that can't read well - this all can vary depending on what YOU pay for fuel in your area.
Here in New York - today:
Household Propane makes 10,500 watts at a cost of $6.73 per hour.
Gasoline makes 10,800 watts at a cost of $5.66 per hour.
Off-road diesel makes 11,200 watts at a cost of $3.70 per hour.
Highway taxed diesel makes 11,20 watts at a cost of $4.53 per hour.
More details:
12,000 watt propane can make 10,500 watts for 38.5 hours on a 100 gallon tank. (Coleman)
At $2.59 per gallon that costs $259 to run 38.5 hours, thus $6.73 per hour.
12,000 watt gasoline can make 10,800 watts for 58.8 hours on a 100 gallon tank. (Winco)
At $3.33 per gallon that cost $333 to run 58.8 hours, thus $5.66 per hour.
12,000 watt diesel can make 11,200 watts for 83 hours on a 100 gallon tank. (Kubota diesel)
Farm fuel at $3.07 per gallon that costs $307 to run 83 hours, thus $3.70 per hour.
Highway diesel at $3.76 per gallon costs $376 to run 83 hours, thus $4.53 per hour.
Your next comment:
"On top of that a diesel engine will cost much more up front than a gas or propane powered unit that gains you little even if you use your 150 hours a year total. "
Well, your have a faulty premise to start with - i.e. your comment "gains you little."
Also about cost. Cost is not just what you pay up front, it how long the unit lasts and how much fuel it uses doing so. There are many good deals to be found with extremely HD diesel gensets at a low price when bought used or reconditioned.
Now, this IS an antique tractor site - correct? So, I'll assume that at least some people here have some mechanical aptitude. Perhaps you are lacking in this department.
I have a Delco diesel 12 KW genset I bought for $1400. I've had it five years now and used it a lot. It has a Detroit Diesel and runs at 1300 RPM. All parts are available cheap (engine and gen) and it's easy to work on. Same units are available "factory reconditioned" right now for $3000. You can easily go to Home Depot and pay close to $3000 for a gas-powered Guardian standby unit at 10,000 watts for $2600.
I can buy, right now, a brand new, Chinese Diesel water-cooler, 1800 RPM 12KW genset for $3800. These units are installed and used all over the world.
A Coleman 10KW gas genset with a Honda engine costs $3100 and has a limited 5 year/1500 hour warranty.
A Kohler LP and NG 12KW genset costs $3300 with a 3 year limited warranty. Engine is GC CH740 that runs at 3600 RPM.
A Norpro diesel 12.5 KW genset costs $7400 with a Yanmar engine. Has a 5 year, 5000 hour warranty.
The Chinese Diesel 12 KW genset costs $3800. Has a water-cooled 1800 RPM engine. Some places sell it with a 1 year unlimited hour warranty, and some with a 6 month unlimited hour warranty. Many of these units have been documented to run 50,000 hours without a teardown.
Now - in regard to your last comment towards me:
"If you don't want details don't ask for them."
Yes, I do want accurate details and I am open-minded. I'm also a more careful reader than you, and apparently better informed.
the Unforgiven
01-23-2008 14:11:42
Well, according to you, "not by much" is about ten percent. I was refering to the loss of power in a low compression engine burning lp vs. gasoline, I did not figure in this fellow's local economy 'cause I just don't know much about his situation. I filled one of my bulk tanks last week, $1.88. The freeze-up is a bit of a moot point, if you get enough water in a gasoline or Diesel system they can be hard to start too.
jdemaris
01-23-2008 16:03:02
 Re: Generator buying advice in reply to the Unforgiven, 01-23-2008 14:11:42
I'm not sure we're in disagreement about anything. Propane certainly has advantages for part-time users. That's true especially with gensets that spend years not being used at all - and there are many.
What I've been talking about is the cost of making electricity, period. It IS an issue to some people. My neighbor has a solar off-grid electric system. This year, he had to use his generator 2 hours a day, almost every day - for two months since it's been so dark here this year.
He uses a propane genset in the winter and a diesel in the summer. The propane is more expensive to make the same KWhs - but - propane is expensive here and off-road diesel is a much better BTU bargain. That could change, and I'm sure those price-disaparities differ in other parts of the country. I will also add that he's gone through two, and is now on his third genset in 7 years. And, the warranty was not honored on last one because the "small print" voids the warranty if the genset is installed for an off-grid household. Seems they only want to honor the warranty if you promise NOT to use it much.
His problems are not fuel related, they are electronic. All three are 10,000 watt Guardian series and cost $2700 each. He also has a problem with the newest one since it's won't support the autostart feature in his inverter/charger system that monitors battery-bank voltage. His diesel genset is a Kubota water-cooled unit. He bought it used almost 10 years ago, uses it every summer and fall, and it's never had a single problem. He doesn't use it in the winter since it's just too complicated with weather that drops to -30F at times.
Prices vary all over the country with various fuels. If you live near deep-water ports, often gas and diesel is cheaper than inland. Propane? Also varies wildly, regardless of average prices Nationwide.
Here in the Northeast, propane has not been a good buy in years - and maybe it's never been.
I installed many electric hot water heaters 30 years ago - and yanked out the propane units. Then electric went up, propane stayed more stabil, and I was yanking out electric heaters and installing propane. Now - around here it's all-most a break-even deal. No real savings by switching to either at present. Natural Gas is still the best buy, but only city dwellers can get it around here.
But, back to the general principals of propane versus gas or diesel - propane has the least energy per gallon, and propane engines are also the least efficient. That can be offset only if the propane is a very good buy as compared to the other fuels.
Take these tables and figure by whatever your fuel cost you.
12,000 watt diesel can make 11,200 watts for 91 hours on a 100 gallon tank. (Isuzu diesel)
135 Fan
01-24-2008 12:05:55
 Re: Generator buying advice in reply to jdemaris, 01-23-2008 16:03:02
I live up in the cold North so maybe I can give some input on the propane issue. I used to live in a mobile home with a propane furnace. It was not uncommon for the temperature to get below -40 deg. I have had the regulator freeze and stop propane flow. I boured hot water on the regulator to thaw it out. Drawing propane out can cause freezing the same way a large liquid oxygen vessel at a hospital does. Co2 will do the same thing as well. larger diameter piping and heaters or heat sinks are used to prevent total freezing. Most vehicle propane systems have a regulator heater attached to heater hoses to prevent the regulator from freezing up. Additionally the propane company that supplied are tank and propane suggested that we put a hot plate up against the bottom of the propane tank in very cold weather. Some people would stack bales around their tank. This was done so the propane wouldn't gel. I have used tiger torches in the winter and the propane tank would form a layer of frost on it and the flame would almost completely go out unless you warmed the tank up. While water isn't good in gas or diesel, clean fuel doesn't create condensation while being drawn like propane can. If a generator was inside a building or the temperature never went too low, propane could be a good choice. Keep in mind that large generators like used for gravel crushing use diesel rather than propane. For oilfield applications, like gas plants, diesel engines converted to natural gas are used because the gas is right there. Dave
jdemaris
01-24-2008 12:19:22
 Re: Generator buying advice in reply to 135 Fan, 01-24-2008 12:05:55
I'm well aware of the what can happen with propane. It's gotten down to 35 F below here (real temp, not windchill). I've had to help thaw out many a propane regulator to get someone's heat going. Never happens with oil (if the tank is inside) and most are around here. My gas supplier carries an ethanol injector and uses it on his housecalls for freeze-ups. Propane systems with single-stage regulators are particularly prone to the freeze problem by creating a temperature drop. Propane vapor can freeze at 44F below.
T_Bone
01-22-2008 14:25:21
Hi Mark,
Tell us more about your 5-10kw demand loads, ie; what type etc, as then there might be some suggestions as how to supply that demand with controls. 3hrs a week is a small demand.
Since your off grid, I would stongly research solar PV using storage battery's with using demand load controls. No fuel to burn and piece and quite.
A genset needs rebuilt and fuel and makes lots of noise and break down just when you need it.
T_Bone
tractormarkb
01-23-2008 05:38:13
 Re: Generator buying advice in reply to T_Bone, 01-22-2008 14:25:21
I have 6 250 amp AGM's and a 2000W(I think)full sine Xantrex inverter with a 100 amp battery charger built in. I use all florescent lightbulbs and run a efficient refridgerator, tv,washer/gas dryer and 12 volt shur flo well pump. Ive been using a 5.6k 5hp briggs and straton based generator I usually use to charge while washing clothes and let run until batteries reach 12.5 volts
T_Bone
01-23-2008 16:16:31
 Re: Generator buying advice in reply to tractormarkb, 01-23-2008 05:38:13
Hi Mark,
Well from what you have, it appears you need too seperate your engine from your generator. You might want to research China Listner diesels that burn 1/2gal/hr, low RPM. Easy to rebuild and the cost wasn't that bad, about $800 delivered a couple years ago. And yes I looked for my bookmark and couldn't find it. Someplace in Washington State tho. This way you only need to replace the parts that's needed, not the whole genset.
You can also make your own fuel from waste oils (WVO) or such. They'll burn just about any type of oil that's clean. The heavier oils may have to be heated or mixed to thinn. TP or paper towels make excellant filters for used oils.
PV's are great but costly but there also a add on system that you can add to each year as money becomes available. The 160w PV's seam to be a good buy this past year, about $650eh for 10a/hr. Charge controllers are under a $100. I'd stick with a brand name tho. I use Uni-Solar on my RV as there unbreakable. Kyrocero is another good brand. I'm sure JD can make a few suggestions too.
I've also had better service from Flotec pumps. I've used sur-flo for many years but lately I can't get them to last very long. Flotec pumps also pump more gpm and cost about $30 more.
You can add a contactor to the refer to shut it off when washing, etc;. A refer can stay off for a couple hours without gaining too much heat. A contactor has a pilot(control) voltage, 24vac to 240vac or more available, then operates a set of line voltage contacts for controling loads.
Another good demand circiut can be made from lawn sprinkler timers, cheap cost $30, as the pilot operator to control a contactor(about$40 for low amperage ones) or relays (about $25 to $40). Contactors will last longer as there heavy duty made but are larger in size. Relays are usually for controlling light demand loads.
The object of load controls is too control peak demand loads so all the appliances can't start at one time thus you can use smaller generating equipment that may cost less to run. In any event, you still have to produce the amount of total watts your using over time.
Another project I'm going to add is a methane generator. A farmer in England runs his entire farm from a 10ft dia x 18" deep MG. Concrete with a top at the surface for solar heating, a gas discharge pipe, a loading door. He uses any type of composting materials, 1part nitrogen, 3parts browns and water. He only recharges once per year and runs his entire farm off methane gas, including tractors and pick-up.
T_Bone
tractormarkb
01-24-2008 07:49:43
 Re: Generator buying advice in reply to T_Bone, 01-23-2008 16:16:31
I have a 2001 toyota minivan with a strong V6 engine and have been toying with the idea of monting a Generator head on it. the vans drivetrain and body are shot but the Engine purrs like a kitten. However Im not sure how much fuel per hour this would burn and it would be hard to figure the correct pulley size to run the Generator. After disconnecting the power steering and Air cond this engine should be able to power even a large gen head. your thoughts TBone?
T_Bone
01-24-2008 22:46:52
 Re: Generator buying advice in reply to tractormarkb, 01-24-2008 07:49:43
Hi Mark,
All 4pole generators turn at 1800rpm and all 2pole generators turn at 3600rpm.
I'm not going to repeat what JD said in his excellant info in this thread about fuel types with using BTU's/hr for comparring fuels.
Gas engines can work as generator movers but are costly in both maintance and fuel consumtion. Any time you run a engine above maximum torque then fuel consumtion greatly increases to achive maximum HP. Torque is king at moving load weight, HP is king at winning races but at a very dear cost.
A gas engine typicaly has a sharp peak torque curve where as a diesel engine has a farily flat torque curve. It would be more difficult to design a genset with a gas engine as the engine wants to hunt RPM on either side of the peak torque rpm.
Once you get your generator set up to accept any external engine then it's only your choice as what type of engine to use. Generators, usually out live the engines many times over.
T_Bone
bill mart
01-22-2008 14:42:07
which would happen first? the batteries need to be replaced or the genset needs a rebuild? and what are the costs involved in each?
jdemaris
01-22-2008 15:19:52
 Re: Generator buying advice in reply to bill mart, 01-22-2008 14:42:07
Dollar for dollar, the 6 volt deep-cycle golf-cart batteries greatly outperform any "specialty" solar storage batteries.
Trojan T-105s have been the most popular for years in off-grid setups. Last year they were $55 each and they often last 7 years, and somtimes 10 years. But - like everything else, the prices up and are now over $100 each.
For somebody that only uses the batteries part-time - e.g. every summer - sometimes buying 12 volt "almost deep-cycle" like Walmart sells is a better deal. They tend to last 5 years. I got one place that I use them all summer hooked to solar. Then when winter comes, I take them home and stick them in tractors for winter starting.
In regard to the gensets - it all depends on how much use. If you're cheap and want longevity, but an older, slow-running water-cooled genset. You can buy a Detroit-Diesel powered Delco 12 KW unit used for $2000 and with proper maintenance, it could last you a lifetime. Runs at 1300 RPM which is nice and makes clean power.
jdemaris
01-22-2008 14:11:26
 Do your homework in reply to tractormarkb, 01-22-2008 06:06:00
You better do your homework. An off-grid situation has certain problems I don't see mentioned in the other posts.
Hopefully, you've got a battery bank. If not, you're throwing your money away no matter what generator you use. A generator needs to be run at the peak RPM range to run most efficiently -and it needs to be sized to the job. So, to do this - you need to operate most of the time off a battery bank - and when it gets low - run the genset at peak power until the batteries are charged and then shut it down.
How are you going to charge the battery bank? Most portable generators only put out 140 - 150 volts at the peaks of the cycles. Grid power is 170 volts at the peaks. Due to this - conventional battery chargers do not work properly on most gensets. To correct, you need a generator that does make the proper current - or - use a special 10-15% voltage corrector - or - use an electronic battery charger like an Iota.
In addition - if you have an inverter/charger - many of them do not accept power from most gensets. A Trace/Xantrex mod-wave DR unit doesn't. A Trace/Xantrex full-wave SW type does.
A full-wave Outback systems usually does not.
I know many off-gridders that have wasted tons of money on bad gensets based on bad advice. It's expensive to learn the hard way. Most people in the off-grid business have lists of which generators work well with chargers , and which ones do not. Also keep in mind - that many gensets will void warrantees if hooked to an off-grid cabin or house - read the very small print.
A DC generator works best if all you need it for is battery charging. I have a 4000 watt powered by a Subaru gas and propane unit. I rarely use it though - it's basically for backup. If I had to make power for many hours - I'd use my diesel.
Many off-gridders make their own from DC auto alternators and five horse engines. The 4000 watt gensets with multi-fuel Subaru 8 horse engines can often be bought brand new for $300. The market was flooded with them awhile back due to a Telecom company that went under and had hundreds of them, brand new, in storage.
I've got three places on solar - two off grid, and one grid-tie. My small cabin in the woods (off grid) has a 1000 watt solar array, four deep-cycle batteries to make a 12 volt bank, a Trace DR2400 inverter/charger, and a 5 horse DC generator and the system works great. I've been building up there for two summers. I run power tools, my wife watches TV, etc.
In regard to fuel choices - propane is very inefficient. For your dollar - you get the least engergy from propane, more from gasoline, and more yet from diesel (especially off-road diesel).
Many people like propane anyway because it works well with an auto-start system. Diesel in cold areas can be a real problem. I own property in the Michigan UP and live here in central New York. It gets colder here - sometimes down to 35 F below - so I'm well acquainted with it.
I'm curious to hear exactly what you are using the genset for. I've worked on many off-grid systems and might be able to point you in the right direction.
tractormarkb
01-25-2008 05:40:26
 Re: Do your homework in reply to jdemaris, 01-22-2008 14:11:26
I am charging 6 250 ah amg batteries, using a xantrex full sine wave inverter 2000w. running energy efficent lights bulbs and fridge, washer/gas dryer,12v well pump on a 'fall well'.I heat with wood only. I also use a 8OOW AC windmill that sometimes spins when we get a good wind.
jdemaris
01-25-2008 07:04:26
 Re: Do your homework in reply to tractormarkb, 01-25-2008 05:40:26
That's close to the same system I have up in the Adirondack mountains. It's off grid, I have eight 225 AH 6 volt deep-cycle battries wired to make a 12 volt battery bank. My inverter is also a 2000 watt Xantrex but mine is the DR series that does not have as sophisticated a battery charger as your SW series. I have 1000 watts in solar panels, but no wind supplement. We run a propane clothes dryer, 19" TV and DVD player, CFL lights, 12 volt water pump, and a 12 volt refrigerator and freezer - both Sundanzers.
We had propane units before that, but the Sundanzers on 12 volts have been much more efficient overall - especailly with propane being so expensive now. One side-note on refrigeration. A friend of mine borrowed my Sundanzer freezer last summer while he camped for two months. He turned it down a bit and used it as a frig and a freezer. He used it two months with a single Kyocera 120 watt solar panel and two 225 amp 6 volt deep-cycle batteries. That's here in dark and gloomy NY with poor sunshine. He had more power than he needed and also charged power tool batteries, watched TV, etc. I'm building up in the Adirondacks every summer and running many power tools which eats up power. This requires using a generator once in awhile to charge batteries back up. Also, when running power tools, I've not been using my Xantrex inverter. It works fine - but I've been using a cheap Chinese 3000 watt inverter from Harbor Freight instead. It cost $130 new and has been bullet proof. I've used it two full summers with zero problems. I figure it saves wear and tear on my expensive Xantrex unit. In my situation - the Xantrex DR built-in 70 amp battery charger will barely make 30 amps on most AC generators. Your SW unit is supposed to be much more efficient and tolerant of cheap gensets. For me - I have several remedies. I use any cheap genset hooked to an Iota electronic battery charger and all works fine. Seems a shame though, not being able to use the one built into the Xantrex. To use the Xantrex charger, only my Honda inverter charger works - or my big Fairbanks Morse 14 KW until that's powered by a F162 Continental gas engine. Both make very clean power. I also have a 4000 watt DC genset powered by an 8 horse Subaru engine. It works great but runs on propane which is costly. In your situation - I assume you want to use the "autostart" feature that's built into the SW inverter/chargers if that's what you have? If so, watch out with new consumer-level standy generators like sold by Home Depot since many will void the warranty if they find out you've got a off-grid setup. Check the warranty carefully. If this is something you are doing long-term, and you want the best "bang for your buck", a good used generator is the way to go. Keep in mind that many get bought and never used. My Fairbanks Morse was built in 1961 and installed into a high school and was never used - not even once. It was just fired up once a year and tested. I paid $400 for it and the paint isn't even burnt off the exhaust yet. Many of these larger and older gensets are extremely heavy duty and simple to work on. I've read all the gloom and doom already posted about not buying used gensets - so I guess you have to make up your own mind. From what I've found - unlike cars, trucks , or tractors - many gensets sit for years without ever being used - especially the heavier standy-type units. I've come across many and have over a dozen. Pick your fuel of choice and work from there. Propane will be, by far, the most expensive to run - but still might be a good choice if you already have a large propane bulk-tank. A diesel came make the same amount of power at almost half the cost if you buy dyed diesel. But, the diesel will much more difficult to use in cold weather. Most off-grid experienced people will tell you nothing beats the older Kohler, Onan, Kubota, or Delco diesel standy units. If cared for, they can last forever and all can be hooked to autostart except for extreme cold setups. Also keep in mind that if you must have propane - most older gensets made for gasoline can be converted for a few hundred dollars. If you only want new - and don't have much money - you will get twice the machine for your money if you buy Chinese but do so carefully. Some of it is absolutely junk - and some other very rugged and time-proven. There are remote off-grid places all over the world using either the British Lister diesels like the Alaska poster mentioned - or the Chinese diesel clones of the Lister machine. You can buy a new 5000 watt diesel genset for $1400. You can also find a 5000 - 8000 watt Honda or Yamaha genset in "hardly used" condition for less than $1000 if you shop around. My neighbor has one he bought during the 2000 milenium scare and it's been sitting in the unopened box for 8 years. That is not uncommon. Keep in mind that even the Hondas are made in China - so if you are "anti Chinese" - well good luck finding something.
Leland
01-22-2008 12:54:45
get a pto driven one if you have a small tractor ,neighbor has an IH H tractor and it seems to run for ever on fuel when power goes down .
135 Fan
01-22-2008 12:18:14
I have a Robin Subaru generator. They make some of the generators for JD. They have several models including diesel and high end inverters. They are every bit as good as Honda and on mine it is brushless, which is a bonus. The place I bought it from told me they sold a bunch to a big construction outfit that used to run Honda's but switched because dirt would get into the brushes on the Honda's and then have to be repaired. The Robin's are as quiet as Honda's and usually cost a lot less. They come with a 2 year warrantee, even if used for commercial, I believe. I agree that I don't think you'll find a decent 5 KW for anywhere near $1000. I would buy a generator from a dealer that services them. I don't think propane uses a choke. Something with a B&S engine is going to be loud and won't last as long. The same for Chinese copy generators. Good luck. dave
JT
01-22-2008 11:32:03
Unless you buy one the cheap Chinese generators you will not find a good one for less than $13-1400.00. Now, Honda is probably the best, followed my Mitsubishi, then Generac/Guardian. you can also get a Briggs generator, with a newer Intek engine, and they are good generators. but you will still spend about 1200.00 for on with electric start. If you are looking for something that is going to be dependable for a long time, you need to double your budget, and at minimum, get a Generac/Guardian, I have one that starts easy, and I started it a couple weeks ago at 15-20 degrees, started right up. Now, if you so not want something as good as the Honda, Generac, Briggs, but not as cheap as the Chinese generators, you can look at the Powermate generators, but as soon as you get it home, order a set of brushes, and a capacitor, if it uses one, you will need both at some time. That is the two parts we replace the most on the Powermate generators.
Jim
Harken
01-22-2008 08:48:44
I have gone through many generators over the years in the construction business. Since I make my living using them they must start and work properly. I can't afford downtime in the middle of nowhere.
That said, if it doesn't have a Honda engine on it I won't buy it. I started mine, 5500 watt, yesterday on the first pull after sitting on my truck in 15 below weather. It runs forever on a tank of gas. Same with my mixers and packers.
TractormanNC
01-22-2008 08:25:50
Don't think you have a snowball's chance in h*** of finding a 5-10kW for less than $1k unless you buy used. As critical as it appears from your post, I wouldn't even consider a used one. A 10kW gen alone without engine will be somewhere around $600-$800.
CH(upstate,NY)
01-22-2008 07:33:59
I've had an Onan like in the link at my place in the Adirondacks for 16 years. It's a backup for my solar. At 100 hrs. the maintenance manual said to remove the heads and clean carbon from heads, valves and piston. At 105 it started knocking. I cleaned it up and converted to propane. I've got just over 1000 hrs. on it with no problems. It starts at 35 below zero everytime.
timcasbolt
01-22-2008 14:09:26
 Re: Generator buying advice in reply to CH(upstate,NY), 01-22-2008 07:33:59
Another vote for the Onan on propane. Very reliable, and quieter than most.
Chris(WA)
01-22-2008 07:24:52
I have a friend that lives off the grid in Alaska. He has a generator out of a fishing vessel that he uses for power daily. Lister Diesel. Just comes in the house and flips a switch. It starts up and everything comes on. Never will forget the first time I was there. Ten miles up river on the ice into the bush to his "Fish Camp". Got to his house. Here is this beautiful two story home with big bay windows. Go inside. He hits the switch and everything in the house started up, stereo, big screen TV ,all the lights, computer, he turns to me and with his very distintive(he is a native Yupeck Indian) accent says" God Dang KIDS!" Alaska is definitly part of America and it is the twenty first century there too! LOL!!
