Tool Talk Discussion Forum
Get it properly repaired B-4 it falls apart!
Bob
11-08-2007 14:39:30
There's 4 capscrews down in the bottom of that tilt wheel joint that COMMONLY shake loose.
It takes a bit of labor to get in there, but if you don't get them tightened back up, eventually the column will literally fall apart.
Suggest you find a REASONABLE mechanic who's been through this before, and get a quote for the couple of hours of labor that it takes to get the capscrews TIGHTENED (with a little Loctite, so it doesn't happen again).
Linked below is ONE site that explains how to do it yourself.
chuckinnc
11-09-2007 05:41:09
 Re: Get it properly repaired B-4 it falls apart! in reply to Bob, 11-08-2007 14:39:30
Great link, I guess i will tackie it because finding a honest auto mechanic in my area would
take a lifetime for a young man and im allready 54.
shannon from ohio
11-08-2007 16:31:00
Yep, Been There,Done That. A little time consuming..... .
Marsh M. Ehlo
11-09-2007 06:42:07
 Re: Get it properly repaired B-4 it falls apart! in reply to shannon from ohio, 11-08-2007 16:31:00
Yep, Been There,Done That..... ..... .....
pretty common truck, and problem
