Tool Talk Discussion Forum
Try MSC Direct
SWI_Don
09-04-2007 19:14:31
MSC has several made in usa plugs. Black pipe 150 class plugs rated to 300 psi up to 4" in dia. A 2.5" black pipe plug was around $6.50. Not cheap but should be a quality piece.
Grainger or McMaster may have them too.
I used some loctite thread sealer on my log splitter to seal the locally sourced asian pipe threads after the Harvey's non-PTFE stuff from Menards didn't work. It's and anerobic sealer you put in two threads assemble and wait overnight or add some kicker and heat and be cured in a couple of hours. I did mine last winter and used halogen lights overnight to keep the joints warm so they would cure. I think the number is 545.
Don
