Tool Talk Discussion Forum
air compressor tank question -
mud
09-04-2007 07:05:07
I'm trying to seal up the inspection plugs on a 30 gal. tank. Needed to pull the old plugs in order to clean out the tank and inspect it. The old plugs had to be cut out. The threads in the holes are all fine.
Now the new plugs are not sealing well enough to hold water for a hydro test. I'm using Rectorseal pipe thread sealant. The plugs leak even though the threads are well seated.
Is there a better pipe thread sealant that will hold against the pressure test? I'll be pressurizing it to 200 psi. Thanks -mud
Old Magnet
09-04-2007 19:35:02
 Re: air compressor tank question - in reply to mud, 09-04-2007 07:05:07
Try hydraulic system threaded plugs (dry seal) they are a tighter thread.
SWI_Don
09-04-2007 19:14:31
 Try MSC Direct in reply to mud, 09-04-2007 07:05:07
MSC has several made in usa plugs. Black pipe 150 class plugs rated to 300 psi up to 4" in dia. A 2.5" black pipe plug was around $6.50. Not cheap but should be a quality piece.
Grainger or McMaster may have them too.
I used some loctite thread sealer on my log splitter to seal the locally sourced asian pipe threads after the Harvey's non-PTFE stuff from Menards didn't work. It's and anerobic sealer you put in two threads assemble and wait overnight or add some kicker and heat and be cured in a couple of hours. I did mine last winter and used halogen lights overnight to keep the joints warm so they would cure. I think the number is 545.
Don
Bob
09-04-2007 07:48:29
Chase the threads with a pipe tap of the appropriate size.
Don't get carried away, just enough to clean them up.
With clean threads, there's NO reason the plugs shouldn't seal 100% with the sealant you're using.
Chris(WA)
09-04-2007 07:27:50
Use at least three wraps of teflon pipe tape then thread sealant. Sound like you have some of those finely made overseas pipe plugs that are about all you can buy today...
mud
09-04-2007 07:32:53
 Re: air compressor tank question - in reply to Chris(WA), 09-04-2007 07:27:50
Yep - can't seem to find anything else for plugs. ugh.
135 Fan
09-05-2007 20:35:26
 Re: air compressor tank question - in reply to mud, 09-04-2007 07:32:53
Steel hydraulic plugs should work better and you can tighten them more if need be. Dave
