Tool Talk Discussion Forum
Won't this help keep the signal
oldfarmtractor
07-26-2007 20:35:57
I don't have either system but if I did, I think I would go out and get the maximum signal in a light to medium rain. After all you lose signal because of difference in the index of refraction between water/rain and air, right?
So, using Snell's law, if you do the maximum signal in the light rain, it will bend one way when it gets clear and the other way when it gets more rainy.
Anyone have an opinion on this?
KEB
07-27-2007 08:44:19
 Re: Won't this help keep the signal in reply to oldfarmtractor, 07-26-2007 20:35:57
Loss during storms has very little to do with refraction and a lot to do with absorbtion. Signal loss during storms is more of a problem at higher latitudes because your're looking through the atmosphere at a lower angle (closer to the horizon) and the signal has to travel through more clouds.
I've had both Dish & Direct, and don't see any significant difference between them.
Here in Colorado the only time we have real problems with signal strength is when it snows and accumulates on the dish itself. Have to go out & clean off the dish (fortunately its on the edge of the balcony where we can reach it). I can only think of a time or two when we've lost signal because of rain, and then only long enough for the thunderstorm cell to move through.
Keith
07-27-2007 05:32:35
The current locators and digital meters peak the signal to the highest possible angles. You can't get it any better so there is no reason to get wet while peaking angles. The meter that our guys use is the birDog.
