Tool Talk Discussion Forum
How much compressor do I need?
Rod in Smiths F
06-20-2007 04:51:47
Thanks for the comments so far. I looked up hydroflouric acid and it looks way too dangerous to use on an inside wall. Unlimited water as a neutralizing agent all over my hardwood floor doesn't sound good either.
This leaves the sandblaster. A vacuum should be able to remove the residue from an unfinished hardwood floor.
I have 15 amp 220 service in the room now to run my shaper. If I went to Princess Auto to get equipment for the sandblasting project, what would I need to buy?
Thanks,
Rod
Wardner
06-20-2007 23:49:21
 Re: How much compressor do I need? in reply to Rod in Smiths Falls, ON, 06-20-2007 04:51:47
You need to rent equipment or hire a professional. You will need something like a 25hp portable air compressor, a pressure pot (sandblaster), air fed helmet and pump, and high CFM fans to expell the dust. The fans will use all your 15 amps of 220v.
Old lime mortar creates an instant white-out when it is sandblasted. I know. I have done hundreds of thousands of sq ft of interior brick in old mill buildings. Rubble masonry present some challanges as you are likely to find voids in the mortar.
As a beginner, you will have difficulty doing a good job. Moreover, sandblasted masonry looks different from less destructive cleaning methods. You may not like the effect. It's a personal taste thing.
It is hard to comment on a job I haven't seen. I might advise a homeowner to try scrub brushes and muriatic acid. Use rain gear, face shields, rubber gloves, and forced ventilation. You could also use the hydroflouric acid in the same way. Be sure to dilute it to around 20% of full strength. Yes, it can cause lung damage and skin burns so you need to be very careful and follow mfgs directions. You might want to go to the SureClean website for more info on their various products. I don't know what their site looks like as I used to buy straight hydroflouric from a local marketing company.
On the whole, I think you should hire a professional with lots of experience. Not some wannabe contractor who just bought some equipment cheap at an auction.
markiz41
06-20-2007 05:01:20
Don't even mess with an electric compressor for this size project. Rent one of those towable diesel jobs that puts out 135 cfm and a pressure pot blaster. You'll be done in no time.
06-20-2007 19:38:22
 Supplies and safety equipment? in reply to markiz41, 06-20-2007 05:01:20
Mark:
So to clean 250 square feet of wall what supplies would I need to go with a 135 cfm compressor? Could you describe the safety equipment I should get?
Thanks,
Rod
