Tool Talk Discussion Forum
Pic of sleeve puller
Keith-OR
04-18-2007 22:42:54
here is the sleave puller that I made. I used 3/4 althread and founf a shaft that was close to the size of the outside diameter of the sleave, cut a 1 inch doughnut from it. then I used a piece of tef-plate to make another doughnut same size as the inside diameter of sleave(You can use plywood for this item). drilled 3/4 hole in center of both disk. Then I welded a 3/4 nut to the bottom of the steel disk... the rest you can see from pictures how i made the rest of puller.. HTH
Keith & Shawn
third party image
third party image
