Tool Talk Discussion Forum
Work smarter, not harder. . .
Maine Fordson
04-16-2007 16:05:37
If you are just looking to be able to access the majority of the surface area without actually digging around the stone (i.e., "making gravel"), try an old trick my grandfather showed me:
Take an iron crowbar and drive it down into the ground in several places, close to the stone and all the way around it. Then take a handful of cracked corn and dump it into each hole. Next, put a small fence around the stone a few feet out from it, and pen up a couple of pigs inside.
The pigs will root out around the stone to get at the cracked corn. If you need to get deeper, drive more holes with the crowbar and add more cracked corn until you get the depth you need.
Once you do this, the stone will no longer be half-buried, and you can get a chain on it or do whatever it is you plan on doing next. . .
For me, the next task would be finding equipment big enough to move something of that size and weight -- I'd strongly consider splitting that stone in half at least once before trying to move it; it's awfully easy to break equipment and bend things when dealing with this kind of super-heavy stuff.
-- Maine Fordson
