Tool Talk Discussion Forum
WATCH OUT...
Bob
01-22-2007 09:57:13
If the tank was indeed overfilled, when it warms up, being inside, near the heater, the safety valve may blow as the liquid expands.
That would be NASTY... with liquid propane spewing from the safety valve.
That's why they went to the "OPD" valves with a float, so the tanks can't be overfilled.
Is your tank still equipped with the old "POL" valve? I didn't think any company would refill them anymore???
j-tex
01-22-2007 13:01:33
 Re: WATCH OUT... in reply to Bob, 01-22-2007 09:57:13
as far as i know its th new style valve it has threads male and female. I had it filled at a Flying J truck stop, surely they would have said something?? Would it be safe to "drain" some by taking the tank outside and carefully releasing some through the heater regulator/hose with the heater disconnected. if not what do I do?
ScottP
01-23-2007 08:56:37
 Re: WATCH OUT... in reply to j-tex, 01-22-2007 13:01:33
J-tex
Take your tank out side away from any ignition source and open the 10 percent valve. Which should be a screw head on the side of the main tank valve.
Just open the 10 percent valve enough to see if liquid or vapor comes out. You will know the difference. If vapor comes out you ane not to full. If you get liquid leave the valve cracked open until just vapor comes out. The float may have stuck and allowed the tank to be over filled.
Scott
