Tool Talk Discussion Forum
Secondary battery?
jdemaris
01-15-2007 17:38:02
What are you calling a secondary battery? Chevy or Ford diesel use two 12 volt batteries hooked in parallel and they are both used equally. There is no "primary" or "secondary."
mshadow77
01-15-2007 17:50:39
 Re: Secondary battery? in reply to jdemaris, 01-15-2007 17:38:02
I am not that familiar with diesels so I didn't know both were used equally. So it doesn't matter which battery I hook the power cables to?
Mike
jdemaris
01-15-2007 18:06:42
 Re: Secondary battery? in reply to mshadow77, 01-15-2007 17:50:39
Nope, makes no difference. The two batteries hooked in parallel act a one big battery. If you had a situation where you used a lot of battery power, the thing to do is install a third battery with an isolator to prevent it from draining your two starting batteries. If it's just short usage, then no problem.
