Tool Talk Discussion Forum
diesel battery hook up
mshadow77
01-15-2007 17:29:26
I have a 1994 Ford Diesel pickup. I now have a winch that I need to hook to the truck battery. Which battery do I hook it to, the main battery or the secondary battery? Thanks!!!
Mike
John T
01-15-2007 19:41:42
 Re: diesel battery hook up in reply to mshadow77, 01-15-2007 17:29:26
Do you know the max full load amps of the wench motor??? If thats known I would install a circuit breaker sized accordingly right at the hot pos post of whichever battery youre gonna tap from (theyre in paralell as posted) and then run sufficient gauge wire to the wench and have its -terminal well grounded also.
John T
jdemaris
01-15-2007 17:38:02
 Secondary battery? in reply to mshadow77, 01-15-2007 17:29:26
What are you calling a secondary battery? Chevy or Ford diesel use two 12 volt batteries hooked in parallel and they are both used equally. There is no "primary" or "secondary."
mshadow77
01-15-2007 17:50:39
 Re: Secondary battery? in reply to jdemaris, 01-15-2007 17:38:02
I am not that familiar with diesels so I didn't know both were used equally. So it doesn't matter which battery I hook the power cables to?
Mike
jdemaris
01-15-2007 18:06:42
 Re: Secondary battery? in reply to mshadow77, 01-15-2007 17:50:39
Nope, makes no difference. The two batteries hooked in parallel act a one big battery. If you had a situation where you used a lot of battery power, the thing to do is install a third battery with an isolator to prevent it from draining your two starting batteries. If it's just short usage, then no problem.
