Tool Talk Discussion Forum
I have a question
Pooh Bear
06-08-2006 20:07:54
I have a small Arc-110 Harbor Frieght welder.
I got it off ebay for five dollars. Works great.
I"m not a welder by any definition of the word.
And so far I haven"t exceeded the duty cycle.
Even welding at full current with 3/8 rods.
But I have been wondering, Could I add a small fan
to blow air thru the machine to help keep it cool.
Only welding I have attempted was during cold weather.
Don"t know what will happen this summer when it is hot.
Pooh Bear
Stan in Oly, WA
06-09-2006 11:31:21
 Re: I have a question in reply to Pooh Bear, 06-08-2006 20:07:54
Hi Pooh Bear,
It would be a good idea to add a fan. Heat buildup is the limiting factor in the duty cycle of a welder. I have no idea how much difference it will make, but I'd be interested to find out.
There's a typo in your question, I think. A 3/8 electrode would be about the size of a Louisville Slugger (okay, accuracy hawks, that's a joke; don't correct me.) I figure you meant 1/8, right? When you say you haven't exceeded the duty cycle so far, you must mean the true duty cycle of the welder---the one that shuts the welder down when you hit it. How did that amount of time compare to the stated duty cycle?
The reason I'm asking is because I recently had to do a small amount of welding at a location where everything about getting power was a problem. A capable 110 machine would have cut the time I spent by about 2/3. But not all house voltage welders are created equal. I bought a low end 110 stick welder at HF once (an Italian made one in a plastic case.) The main problem with it was that it was absolutely worthless, but it was a nice size. What you're describing sounds much better.
Stan
Pooh Bear
06-09-2006 13:36:40
 Re: I have a question in reply to Stan in Oly, WA, 06-09-2006 11:31:21
You were right. Major typo.
I just checked my welding rods.
1/16 and 5/64 and 3/32. Don't know where I got
the 3/8 number from. Maybe I was thinking 1/8.
I'm thinking I had some ?/8 rods. Must have been 1/8.
I was thinking of a small 110volt fan from Surplus
Supply and I could plug it into it's own outlet.
The welder is 110 or 220 but I only run 220.
It's been fun to play with but I'm no welder.
I did manage to get my two practice peices to stick
together and now I can't get them back apart.
Thanks.
Pooh Bear
