Tool Talk Discussion Forum
Fan in 220V welder
Stan in Oly, WA
06-08-2006 16:03:43
I have several 220 volt welders which are equipped with internal cooling fans. The power supply plugs are of two different configurations but all have three prongs. Does this mean that the fans are using the ground as a neutral, or are they 220 volt fans?
Thanks, Stan
Hal/WA
06-10-2006 00:09:17
 Re: Fan in 220V welder in reply to Stan in Oly, WA, 06-08-2006 16:03:43
Interesting discussion. I never thought about it. My 40 or so year old Lincoln also has a 3 prong plug and of course, a fan. It works about the same as it did when I was a kid, fooling around trying to learn to arc weld. I have never been bit welding with it; I am careful though.
I have thought about adding a ground wire to the metal case of the welder, but haven't done it. Maybe that would make it safer.
Stan in Oly, WA
06-10-2006 07:54:19
 Re: Fan in 220V welder in reply to Hal/WA, 06-10-2006 00:09:17
Hi Hal,
Earlier this year I bought a Lincoln buzz box that had June 22, 1967 written in pencil on the margin of the application chart on top. The ground wire from the plug attaches directly to the inside of the case. I hadn't thought about it before, but what else is there for it to attach to?
This is a 185 amp AC unit which, at second glance, doesn't look exactly like the far more common 225 amp ones. The labeled amperage settings are different, and there is a saucer sized flattened dome on the lower back of the machine behind the transformer. Also, this unit doesn't have a fan. There is one unused wire coming out of the transformer but no empty mounting brackets or unused holes in the case where a fan would go. Besides, one wire is about one wire too few according to the information, admonitions, and sermonettes I've received on the subject.
All the best, Stan
P.S. You're over near the eastern side of the state, aren't you?
John T
06-10-2006 05:27:06
Hal, unless it got burned off or removed/destroyed somehow, that third wire (often bare or green) safety equipment ground SHOULD ALREADY BE BONDED TO THE METAL CASE. Thats the whole purpose and design and reason for having an equipment grounding conductor on the appliance in the first place, to provide a current return path back to the panel to trip the breaker and clear the fault in case a hot phase wire came in contact with that metallic case. Otherwise, if you touched the case and were standing on wet concrete or the earth you could be electrocuted. You could easily use an ohm meter to check the continuity from the plugs ground terminal to the case which ought to be near zero ohms.
I hope we helped the poster with his great question and made things safer and educated others with this very important discussion.
Take care n God Bless yall n stay safe
John T Retired Electrical Engineer
Hal/WA
06-12-2006 18:41:54
 Re: Fan in 220V welder in reply to John T, 06-10-2006 05:27:06
But there are only 3 conductors in the power cord--both hot wires and the neutral. I also would assume (there's that dangerous word!) that the case is bonded to the neutral inside somewhere. And I know for a fact that the neutral is bonded to ground--my metal water piping.
Would it be safer to have a separate ground wire from the case to a known good ground rather than depending on just the neutral? I had a mobile home once and the electric dryer had a 4 conductor cord including a ground. I was told that the code required a separate ground for appliances in a mobile home. But when I built a new house, about 10 years ago, the dryer receptacle just had 3 openings.
And yes, I do live in Eastern Washington, SE of Spokane a ways. On the dry side, although the last couple of weeks have been super wet.
John T
06-12-2006 20:43:24
 Re: Fan in 220V welder in reply to Hal/WA, 06-12-2006 18:41:54
Hal, I bet the welder has a 3 conductor cord as you said BUTTTTT if its like many typical straight 220 volt ONLY AC Buzz Box Welders, that third wire (NOT one of the two hot phase wires) is an equipment safety GROUND and NOT a Neutral. It would only be a Neutral if the welder had say a 120 volt fan which does require a Neutral and in that case, it would still require the seperate safety equipment ground bonded to the steel case i.e. a 4 wire cord (for BOTH 120 and 240 volt use, 2 hots, Neutral and Ground) instead of only a three. Just because the safety equipment ground
could serve the purpose of a true Neutral DOES NOT MAKE IT A NEUTRAL NOR SAFE NOR NEC PROPER!!!!!
The safety equipment GROUND (often green or bare) should indeed be bonded to the welders metal case/frame so that if a hot phase wire got shorted to the steel case theres a low impedance return current path back to the PANEL SO THE BREAKER TRIPS AND CLEARS THE FAULT so you dont get electrocuted if you touch the case!!!!! !!!!!
Its true inside the service entrance main panel or the meter base or at the weatherhead the Neutral is bonded to a grounding electrode such as a metallic water pipe or a driven rod in the earth for a made ground BUT THATS NOT THE SAME AS THE SAFETY EQUIPMENT GROUND thats used to provide a low impedance return current path back to the panel to trip a breaker to clear a fault. The Neutral is kept tied to mother earth which serves as the common zero potential reference on BOTH the secondary and primary (if a grounded Y service) sides of the service transformer. The primary side Neutral is tied at every so many poles and the secondary Neutral is tied at the transformer and the meter base or main panel TO THE MOTHER EARTH ZERO POTENTIAL REFERENCE.
On Mobile Home services the main servie entrance is considered to be on the service pole and its there AND ONLY THERE that the Neutral and Ground busses are tied together plus the Neutral (as explained above) is tied to a grounding electrode for the mother earth zero potential reference. Then they require 4 wires (2 hots, Neutral, Equipment safety ground) to be ran to the mobile homes panel which is considered as a sub panel after the service entrance out on the pole. HOWEVER for a residential service, they only require 3 wires (2 hots and a Neutral) from the transformer to the maIn panel and at the main panel AND ONLY THERE the Neutral and Ground busses are bonded together. At any sub panels downstream after that, however, the Neutral and Ground busses are NEVER TIED AGAIN and it would take 4 wires to serve that downstream sub panel.
Neutral is NOT the same as the safety equipment ground. The Neutral is a current carrying grounded conductor while the equipment ground is normally (except for fault current) a non current carrying conductor. Its sole purpose is to carry fault current NOT the normal return current.
Its indeed true some ranges did not have a 4 wire cord and had both 120 and 240 volt loads but Im NOT aware of any welders that did that and except for these type exceptions ITS AN NEC VIOLATION AND A POTENTIAL SAFETY HAZARD to use the equipment ground as a Neutral
I hope this helps and clarifies the difference in a Neutral and an Equipment Ground and Earth Ground. Its been many moons since I graduated as an EE and am rusty on the NEC since I retired but made my living several years as a power distribution design engineer and contrary to some opinions expressed here, do have some grasp on this electrical stuff and have tried to help n explain it and keep others safe to the best of my abilty and olddddd ddd memory lol.
Best wishes n God Bless yall
John T
Bus Driver
06-09-2006 04:48:28
If one is certain that the fans in the welder are original, look at the nameplate on the welder. If it says something like 208/220/240 V 60Hz, all the parts of the welder use those voltages. If it is 120/240, some parts of the welder use the 120 volts. For present electrical code- and to comply with OSHA, if applicable- any equipment using 120/240 would have 4 prong plugs.
Stan in Oly, WA
06-08-2006 22:21:17
What's up with the massive amount of self-righteous indignation that's been showing up here lately? I asked if the fan of a 220 volt welder was a 220 volt fan or used the ground as a neutral. Since, as Dusty pointed out, ranges and dryers have had 110 volt features for a long time but even now sometimes come equipped with three prong plugs, my question didn't seem immoral. For instance, it wasn't whether it would be all right to kidnap little schoolgirls and force them to install 110 volt fans in 220 volt welders for 20 hours a day, but many of the answers sounded as if that's what I'd asked.
I come to this forum for information and advice. If I felt like I needed to be scolded or I wanted a sermon, I could give my ex-wife a call; all I'd have to do is identify myself, and she'd take it from there.
Stan
buickanddeere
06-09-2006 13:18:23
 Re: Fan in 220V welder in reply to Stan in Oly, WA, 06-08-2006 22:21:17
Everybody either used to use a chamber pot or the old one holer out behind the wood shed. Now that have and know better why take a step backwards with our electrical wiring as well? The so called grounds used as neutrals have either went open due to breakdown or tinkerer wiring jobs. The end result is enough people have been bit with up to 240V . And enough buildings burned down that a four wire system is the law.
John T
06-09-2006 06:09:45
Stan, I agree with you. Theres absolutely nothing bad or immoral in your question and for a guy to ask a legitimate question and for other guys to try n help to the best of their ability, thats what these boards are all about. Im a safety concious retired electrical engineer who designed power distribution systems for a living and sure dont want to see any harm or injury come to no one or their family. Im glad you asked your question n hope you got some good help here, if theres anything else we can help you with please ask.
John T
evielboweviel
06-09-2006 04:37:25
Once again people with little knoweldge not reading what the question was.
UL approved for years clothes dryers and electic ranges with no nuetral conection and internal 120vac compentents. Also electric ranges used to have a 120vac recptale built into the control panel WITH NO NUETRAL CONNECTION TO THE RANGE and a big UL label on the range.
Ron
John T
06-09-2006 07:23:02
 Re: Fan in 220V welder in reply to evielboweviel, 06-09-2006 04:37:25
I agree and youre absolutely correct, I may even still own an old range that only used the 3 wire (2 hots and a ground) plug. HOWEVER Im not aware of any WELDERS (what his question concerns) that had both 120 and 240 volt, and I still bet his fan is, therefore, a 220 volt.
Great discussion
Yall take care now n be safe
John T
MarkB_MI
06-09-2006 00:52:40
Hey Stan, it seems like any post having to do with anything electrical attracts flamers.
Why were you asking the question in the first place? If you were looking to replace a fan, then you need better info than somebody's uninformed opinion. But you can answer your own question in a few minutes with a screwdriver and a voltmeter. If your question was just academic, then my guess is that the fans are all 220.
Out of curiosity, I took a look at the schematic for my Lincoln MIG welder. The fan is marked "230V/60HZ FAN MOTOR". But there's more: The motor actually has four leads! The two extra leads are marked "24V WINDING AUXILIARY". It looks like Lincoln uses the fan motor as a step-down transformer to provide the control voltage for the gun trigger. Of course, that means you couldn't just use an off-the-shelf fan, you have to buy one from Lincoln.
Also, the schematic for my welder clearly shows the ground connector going to the case, with everything else isolated from case ground. The practical effect of this is that you shouldn't be able to get a shock from the welder output, since it's isolated from ground via the power transformer.
FWIW, I was an electrical engineer in an earlier life. And I didn't see anything wrong with your question.
Pooh Bear
06-08-2006 20:07:54
 I have a question in reply to Stan in Oly, WA, 06-08-2006 16:03:43
I have a small Arc-110 Harbor Frieght welder.
I got it off ebay for five dollars. Works great.
I"m not a welder by any definition of the word.
And so far I haven"t exceeded the duty cycle.
Even welding at full current with 3/8 rods.
But I have been wondering, Could I add a small fan
to blow air thru the machine to help keep it cool.
Only welding I have attempted was during cold weather.
Don"t know what will happen this summer when it is hot.
Pooh Bear
Stan in Oly, WA
06-09-2006 11:31:21
 Re: I have a question in reply to Pooh Bear, 06-08-2006 20:07:54
Hi Pooh Bear,
It would be a good idea to add a fan. Heat buildup is the limiting factor in the duty cycle of a welder. I have no idea how much difference it will make, but I'd be interested to find out.
There's a typo in your question, I think. A 3/8 electrode would be about the size of a Louisville Slugger (okay, accuracy hawks, that's a joke; don't correct me.) I figure you meant 1/8, right? When you say you haven't exceeded the duty cycle so far, you must mean the true duty cycle of the welder---the one that shuts the welder down when you hit it. How did that amount of time compare to the stated duty cycle?
The reason I'm asking is because I recently had to do a small amount of welding at a location where everything about getting power was a problem. A capable 110 machine would have cut the time I spent by about 2/3. But not all house voltage welders are created equal. I bought a low end 110 stick welder at HF once (an Italian made one in a plastic case.) The main problem with it was that it was absolutely worthless, but it was a nice size. What you're describing sounds much better.
Stan
Pooh Bear
06-09-2006 13:36:40
 Re: I have a question in reply to Stan in Oly, WA, 06-09-2006 11:31:21
You were right. Major typo.
I just checked my welding rods.
1/16 and 5/64 and 3/32. Don't know where I got
the 3/8 number from. Maybe I was thinking 1/8.
I'm thinking I had some ?/8 rods. Must have been 1/8.
I was thinking of a small 110volt fan from Surplus
Supply and I could plug it into it's own outlet.
The welder is 110 or 220 but I only run 220.
It's been fun to play with but I'm no welder.
I did manage to get my two practice peices to stick
together and now I can't get them back apart.
Thanks.
Pooh Bear
Dusty
06-08-2006 18:42:09
Not very long ago there was an exception for electric ranges and clothes dryers.
Dusty
dr.sportster
06-08-2006 18:30:22
That would be two hot legs and a ground without any neutral needed.Not all things need neutrals.
John T
06-08-2006 19:15:48
 Re: Fan in 220V welder in reply to dr.sportster, 06-08-2006 18:30:22
Thats absolutely correct, if a load is 240 volt ONLY theres no Neutral required. Its feeders would be the two hot phase wires and the equipment ground. HOWEVER if theres any 120 volt single phase loads, then the Neutral (a current carrying grounded conductor) is indeed required. The equipment ground conductor is ONLY used to provide a low impedance return path for fault current to clear the breaker in case of a fault ITS NOT PERMISSIBLE to use it as a normal current carrying conductor.
John T
wdtom
06-08-2006 17:14:07
I am not an electrician, however I do some basic electrical work and know enough to know that you never use the ground for a neutral. The fans are 220 volts if factory installed. Using the grund for neutarl will work, so if someone had a 110 volt fan and wanted to install it they could have done it. You can check by seeing where the wires lead.
John T
06-08-2006 17:13:47
Stan, I SERIOUSLY DOUBT they would use the equipment ground for the Neutral return, it would be a code violation and not be UL approved, so the fan is most likely a 220 volt and if it uses 3 wires they could be the 2 hots plus an equipment ground. Many of those welders use a 3 prong 50 amp plug for the 2 hots and ground.
John T
buickanddeere
06-08-2006 17:12:47
Using the ground as a neutral is illegal, dangerous and tacky.
Brian G. NY
06-08-2006 16:11:47
All the ones I've seen were 220V
