Tool Talk Discussion Forum
Pickle fork.
Steve from Mo -
05-08-2006 12:23:32
You probably don"t want to heat that, but others may know more than me. There is a tool jokingly called a pickle fork that you use to take such things apart. Most auto parts stores have them.
rustyj14
05-13-2006 07:39:33
 Re: Pickle fork. in reply to Steve from Mo - dangit!, 05-08-2006 12:23:32
Turn the offending joint back until it is against the stops, then, using a large hammer, give the part holding the tapered end of the tierod several sharp raps with your heavy hammer. I have removed many tie rod ends that way, after somebody "borrowed" my pickle (or salad) fork, and didn't return it!
steve in in
05-08-2006 13:00:02
I have tried the pickle fork, twice. There is so much room between the steering arm and the drag link that the pickle fork is pretty useless. I"ve tried penetrating oils to no avail also.
I"m not too worried about the existing drag link, since I have the replacement, but I really don"t want to replace the steering arm too. short of taking it somewhere to have it heated and removed, I don"t know what to do to get it off.
The Lisle pickle fork set I have has both a handle for hammering and one for an air hammer. Neither one got me anywhere.
RustyFarmall
05-08-2006 14:25:50
 Re: Pickle fork. in reply to steve in in, 05-08-2006 13:00:02
Pickle forks come in various sizes. You need a bigger one.
