Tool Talk Discussion Forum
R134 is smaller . . . but . . .
jdemaris
04-17-2006 17:58:51
What the guy told you about the molecular structure of R134 is correct. It is smaller than other refrigerants such as R22 or R12. But, it only causes problems with rubber hoses - and they are usually only used in applicactions with a lot of vibration must be absorbed - like a car or truck that has an engine-mounted AC compressor. The smaller molecular size of R134 and leakage problems in rubber hoses was known years ago - and subsequently all the rubber AC hoses used now are "barrier" hoses. They are called that because they have an extra barrier lining internally to prevent R134 seepage. Some older cars with rubber hoses intended for R12 with not hold R134 as well. Again - none of this has anything to do with AC systems with metal lines - so it does NOT apply to your new refrigerator.
