Tool Talk Discussion Forum
Drop those tools and back away now.... OK the grip
buickanddeere
04-12-2006 05:30:47
Don't install ordinary three prong receptacles on a two wire system unless they are GFI. "So Neutral and Ground are tied together, and ground is connected to a 'grounded' rode.
The way I see it, there is no real Neutral in this type of setup, only line and 'ground'. It works ok, but is not at todays spec, where the ground is a real ground to pick up any 'stray' voltages/amps and send them to a safer place."
You have a neutral which is held to ground/earth potential. Not line and ground wires.
