Tool Talk Discussion Forum
Thanks! and another follow up Q..
Truck
04-09-2006 05:09:29
Hey thanks!.. And a quick question.. What I am calling a mixing tube, it screws inside one of the tubes you see from the outside, using an allen wrench. Where it fits into the brass piece the cutting handle is on.. there are two grooves that could be for O rings. One O ring each groove, or only one in the lower groove? Or none at all?
I might have to break down and hit my local welding guy to find the right O ring. The neoprene ones in my kit don't seem quite large enough in cross section to seal on anything.
I used the torch handle yeaterday with a welding tip and a rosebud tip.. Worked 100 percent. So I know the problem is in the cutting head.
Thanks for all the help. I knew it could be fixed, and it ain't got the better of me yet...
