Tool Talk Discussion Forum
I'm on the same thing?
bjr
02-12-2006 09:00:52
Will look forward to what the responses are? I've done a little research. It looks like Grizzly.com for me. The're china, but I'm poor and the used market is terrble if you're a buyer. There's a site called minilathe that's for beginners like me on a budget. I just want to make fairly crude spacers and bushings for the implements, no close tolerence stuff. Let us know what your research comes up with. bjr
TimV
02-12-2006 10:38:29
 Re: I'm on the same thing? in reply to bjr, 02-12-2006 09:00:52
If your anticpated work sizes are within the range of the mini-lathes, they will do spacers and bushings quite well. I've done dozens of them on mine for my old equipment, and it's rare that you need a spacer or bushing larger than 7" x 14". Most are closer to an inch or two, and these are easy to do on the mini-lathe. As far as tolerances, they're capable of holding a few thousandths with care (taking out backlash before cutting, etc.) which is plenty close enough for most work. In many cases, you'll use a reamer to finish the ID anyway, in which case the determining factor is the quality of the reamer, not the lathe.
Slowpoke
02-12-2006 10:14:19
No close tolerance stuff today. Maybe tomorrow. Keep looking for a good buy on an older American lathe. You'll get your money back when you're done with it. Chinese castings can be very poor quality.
