Tool Talk Discussion Forum
5-10 days
jdemaris
12-16-2005 06:34:45
A high-end battery for a six-cylinder Volvo is usually rated at 700 CCA at zero degrees F. and 120 minutes reserve capacity at 80 degrees F. That reserve-capacity equates of maybe 60 minutes at -20F - also equal to maybe 25 amp-hours at the same -20F. So, take that battery at -20F with a steady 1/5 amp draw, and it will last 125 hours or a little over five days. At 80 degrees F, it will last twice that time - i.e. 10 days before the battery voltage drops to 10.5 volts. Keep in mind, the starter-motor is designed to crank at 9 volts. When the battery is aleady down to 10.5 volt no-load, the starter will be cranking at 6-7 volts which will be slow.
