Tool Talk Discussion Forum
What the heck are you talking about ??
jdemaris
12-05-2005 15:30:51
I don't know what the heck you're talking about. First, according to code, what I have is not only within code, it is the accepted standard in my area when tanks are more than 75 feet from a home. A tank is usually pressurized at 150 PSI. A single stage regulator drops that 150 PSI down to 2 PSI. A two-stage regulator does the same, but in two steps and thusly has two sets of pressure drops. Subsequently, it is less apt to freeze because such freezing often takes place at the site of a large pressure differential. With my setup, it is still two stage regulation - just does it with with separately housed regulators. In regard to your somewhat cryptic remark, i.e. " Man, where to start. I believe there's more to the story that were NOT hearing about." What are you alluding to? I've been here for 25 years - on top of a mountain with a steep dirt road that is considered "seasonal." Due to that, we've had many problems with running out of propane in the winter - usually because the delivery trucks are on a scheduled route. If the day comes when they were scheduled to come here, and the road was too icy for them to make it up, they'd skip our house and wait until the next delivery date. Often, we'd run out before that next time came. So, we asked for a bigger tank to buy us more time - and several companies told us "no" because we didn't use enough gas. And, to compound the issue - we have several older gas stoves with pilot lights - and some companies will not hook up to them. Then, we found a small company that assured us we'd never run out. They put their tanks in - one for the house and one for the barn (for hot water). We ran out twice the first winter. Then, a regulator went bad, and full pressure gas came into the house - and the stove was like a blow-torch. Since then, I've installed double regulators on everything that needs it - but most modern gas equipment already has its own backup regulator. So, after years of bullsh*t, we found a company that told us - if we paid for our own tank - they'd fill us at the lowest rate on an ad hoc basis. So, that's what we did. Paid around $800 for a new 500 gallon tank, bought new regulators - I set the tank in place, and the propane guy came over and filled it. It holds enough gas that no one has to come here all winter. So, now - the only problem is the moisture.
Now, what is it you're referring to in regard to high pressure at my appliances ?? You've lost me again. My system has a 10 PSI regulator (coded red) at the tank, and 2 PSI regulators at the house (coded green) - on the outside - with shut-off valves and side-taps for a pressure gauge testing - before entry through the wall and into the house. This is a common and acceptable practice to cut down on pipe size for long runs. What you said, "You do NOT increase gas pressure to over come this pressure loss" is simply NOT true. There are some homes in my area that run even higher pressure - usally a 20 PSI regulator at the tank. Also, in regard to you saying you've never experienced a propane technician that "would refuse to correct a system mistake that he filled" - I've seen this happen with electricians, carpenters, heating contractors, auto mechanics, etc. I guess things are different where you live - but the reality here is still the same. In fact, the company that was providing us with LP gas when the regulator went bad and nearly blew the house up? I called him and told him what happened, and he said he was busy and it might be a week before he'd come here and change the regulator. So, I told him that if he wasn't going to do it - I would. He got angry and forbade me to touch "his tank and regulator." I informed him the equipment was on my property, it was dangerous, and I would fix as necessary if he wouldn't. I did fix it, and then sent him a letter cancelling service. That's when I decided to change companies again - and finally buy my own tank. By the way, the gas guy came this afternoon. He kind of took me by surprise because he came on foot. Ends up his truck would not make it up the road - since he couldn't get his 4WD to work. It's a fairly new Dodge 1/2 pickup. But, he's the second guy I met recently who's four-wheel drive wouldn't engage. Makes me glad to have older trucks with mechanically engaged 4WD. So, he came on foot with a gallon jug of methanol in one hand, and a hand-pump injector in the other. He put it in, we'll see how it goes. Here's a link with specs. for LP pipe sizing, two-stage systems, etc Link
ADVANTAGES>Link OF A TWO STAGE SYSTEM - less freeze ups and more consistent pressure at the house.
The installation of a two-stage system ---- one high pressure regulator at the container to compensate for varied inlet pressures, and one low pressure regulator at the building to supply a constant delivery pressure to the appliances --- helps ensure maximum efficiency and trouble free operation year round. It is important to note that while pressure at the appliances can vary up to 4 inches w.c. using single stage systems, two stage systems keep pressure variations within 1 inch w.c.. Regulator freeze-up occurs when moisture in the gas condenses and freezes on cold surfaces of the regulator nozzle. The nozzle becomes chilled when high pressure gas expands across it into the regulator body. This chilling action is more severe in single stage systems as gas expands from tank pressure to 11" w.c. through a single regulator nozzle. Two-stage systems can greatly reduce the possibility of freeze-ups and resulting service calls as the expansion of gas from tank pressure to 11" w.c. is divided into two steps, with less chilling effect at each regulator. In addition, after the gas exits the first stage regulator and enters the first-stage transmission line, it picks up heat from the line, further reducing the possibility of second stage freeze-up.
T_Bone
12-07-2005 07:27:31
 Re: What the heck are you talking about ?? in reply to jdemaris, 12-05-2005 15:30:51
Hi Jdemaris,
I can see where you have a misuderstanding to what I stated so let me see if this helps.
All your links that you posted confirm just what I stated;
"Code does not allow for a residental home to have a high pressure LP system. Code requires the gas presuure to be at usage pressure at the entry shut off valve to the structure."
Where you have a problem with this statement is you don't have your temperature/pressures(T&P) correct for LP nor is your water column pressure correct.
I've listed some T&P for LP at the temperatures and pressures discussed in this thread.
LP T&P:
89.78�f = 150psig
28� =----- 49psig 0� =----- -24psig -20� =-----11psig
-30� =----- 6psig
-39� =----- 2psig
So as you can see you can't have 150psi of tank pressure during the heating season as when it's 28� abiment your tank pressure would be 49psi.
Lets now define what W.C. pressure is. Approx 28" of wc is equal to 1psig. 11"wc would then be about 0.4psig or considered low pressure according to UBC. Any pressure greatter than 1psi is considered high pressure according to UBC (Universal Building Code).
So then your statement that 11"w.c. is about 2psi to 4psi is wrong and in that pressure range you would have a high pressure LP system hence my comments that you can't have a high pressure LP system inside the structure as code does not allow this.
You stated:
"Subsequently, it is less apt to freeze because such freezing often takes place at the site of a large pressure differential."
This is a true statement and 99% of all LP problems when used for heating fuel source have a problem here. Why?
Propane is another type of refrigerant, R290 class3. If you refer to my recent article on how the refrigeration process works then you will have a better understanding of why regulators freeze even when the LP system is designed correct. I'm not going to repeat what I've already written so if you have specific question please ask.
Another cause of regulator freeze up is either the regulator(s) have not been sized correct or the supply pipe could be sized wrong. Regulators are sized in the amount of BTU volume they can pass without freeze up. This is usually a huge problem as people like to down size pipe or regulators to save on install costs.
Again refer to your link and add up all the gas demand as stated in input BTU/hr rating and that will be the size of regulator you will need. Generaly, regultors are now stated in 1/4million BTU increments,ie; 250,000BTU, 500,000BTU etc: and are stamped in the regulator casting. Use the next largest size when input BTU gets close to regulator rating.
T_Bone
jdemaris
12-07-2005 14:13:57
 No - I'm not misunderstanding anything in reply to T_Bone, 12-07-2005 07:27:31
I�m not misunderstanding anything here. You have attempted to attribute my response to
your�s to my lack of comprehension. That is ridiculous. I posted the query because I was
trying to avoid purchasing a tool for a one-time job - thus my question about a hand-pump methanol injector. You replied with several non-sequitors and a few erroneous statements. Now, you are citing useless facts that have little to do with the issue. I am not an idiot, nor am I inexperienced or uneducated when it comes to
mechanics, electronics, or simple word comprehension. E.g., here are few statements
from your first post:
�you've pi$$ed off your LP supplier and that is why he won't return your phone calls�
Did I state anything that indicated the supplier was angry?
�Code does not allow for a residental home to have a high pressure LP system�
Did I say anything about having what you are calling a high pressure system?.
�You do NOT increase gas pressure to over come this pressure loss�
You are wrong - raising pressure to increase gas flow is a common and accepted practice.
�I strongly urge you too make amends with your LP company and let them tell YOU what you need to change to come with-in code requirements.�
Again - your statement has little to do with reality. My system has been inspected by
several LP companies and all is within code.
And . . . the facts you�ve now posted relating to temperature versus pressure, water-column equivalents to PSI, etc. have little to do with any of this. My problem was water in the tank and me trying to get some methanol in to treat it. Now, if I was writing a Master�s Thesis, or sitting for my Doctoral Dissertation - perhaps we could merrily throw these facts back and forth and play word games and conduct thought experiments liked a couple of bored college professors. I didn�t, and still don�t see the
utility of providing every possible climatic condition and the subsequent variations in
pressure that exist in an uncontrolled environment (i.e. outdoors). Yes, if I were in
Alaska, propane remains liquid at - 40F and I�d have NO gas flow when things got real cold - but so what?
I asked a simple straight forward question, and you�ve not only replied twice with
nonsense - you seem incensed that I won�t acquiesce and believe it.
