Tool Talk Discussion Forum
They are pulling your leg.
steve from mo -
11-18-2005 08:52:45
You need to have a little Dilbert fun with the teenager at the computer store that told you that. Ask him if he has any thrust capacitors for the impulse generator on your Essex Tri-Directional.
As others have pointed out, you can add a USB port to your old computer if you want a USB printer, and you can use a USB to parallel adapter to hook a USB port on a new notebook computer to your old parallel printer. The problem usually turns out to be that a new printer is cheaper than messing with the old one.
Dale B
11-18-2005 18:37:34
 Re: They are pulling your leg. in reply to steve from mo - dangit!, 11-18-2005 08:52:45
Thats why I need the new printer with built in scanner. I have what I believe is a primitive ignition module from an Essex Tri Directional, and I wanted to post a pic to confirm its purpose. I bought it from a man who had worked at Emerson - Brantingham's Grundy Center Branch house, It was ordered by mistake, and was non retunable, so he took it home. I sensed its rarity, as well as the mans eagerness to sell and snatched it up for a song. It is said to fit only models with the Hawker-Sidley-Lister-Petter multifuel engine and induced draft carb. As soon as I get the Scanner- Printer I'll post the Picture.. Dale
