SAND BLASTERS
ED488N
02-01-2001 11:10:35
I AM LOOKING FOR A GOOD BUT FAIRLY INEXPENSIVE SAND BLASTER. I HAVE A COMPRESSOR THAT RUNS 6.2CFM @90 PSI AND 8.4CFM @ 40 PSI, I DON'T KNOW TO MUCH ABOUT SAND BLASTERS, SO ANY HELP OR SUGGESTIONS WOULD BE HELPFUL.IT WILL BE USED MAINLY FOR SMALL PARTS.I SAW ONE AT SEARS BUT NO ONE THERE COULD TELL ME HOW IT PERFORMS. THANKS
ED
Jeff E
02-08-2001 09:28:37
 Re: SAND BLASTERS in reply to ED488N, 02-01-2001 11:10:35
I've had good luck with a 40 lb pressurized unit from Harbor Freight. Normally priced about $130, last catalog I got from them listed it on sale for $80. Did a lot of previous work with a siphon unit, pressurized unit is much faster, worth the extra bucks if you plan on using it more than a couple of times.
Junkman
02-02-2001 20:52:32
You will need more air, but not as much as Paul said. I run a siphon blaster with my Emglo 5 HP 2 stage putting out approximately 22 cfm @ 100 psi. Pressure blasters use less air and waste less sand than siphon units. Go for the bigger compressor before you try to blast.
John
Scott
02-02-2001 18:56:08
ED-
I just posted my opinion about blasters over at the 9N site. Instead of repeating myself, click below.
Best of luck!
Scott
PAUL8N
02-01-2001 19:11:59
WITH THAT CFM YOU WILL BE ABLE TO BLAST FULL STRENGTH FOR ABOUT 30 SECONDS AND THEN HAVE TO WAIT TO BUILD AIR PRESSURE BACK UP. YOU REALLY NEED TO GET UP TO ABOUT 175PSI @ 20CFM TO GET ABOUT 2 MINUTES OF FULL BLAST. THEY DROP FAST IS WHAT I AM SAYING. IF IT WORKS FOR YOU IT WORKS FOR ME. HOPEFULLY YOU ARE DOING LIGHT BLASTING ON SMALL PIECES.
Tools
02-01-2001 11:59:23
Hi,
Here's what I did for an inexpensive blaster that operates on about the same (probably less) air than you have.
I got a portable siphon blaster. I occasionally use it that way, but got it mainly for the parts, it's the small one for $30. Built a cabinet to look like the ones in the pictures. I use standard picture frame glass and buy old pictures at garage sales. I use an old boxer fan from a stereo to exhaust dust. An old grill grate holds the parts inside.
The trick to it working good seems to be the pickup tube. I hook the siphon hose to a similiarly sized piece of tubing (about 5/16) thats about 14" long. I put that tube in a 12" long bigger piece of tube (about 5/8), evened up on the end that goes in the sand. I crimped the two just enough that they won't slide apart. I leave the pickup tube loose so if it plugs, I pick it up, aim it at the corner of the cabinet, put my finger over the end of the gun and pull the trigger. The offender shoots out the end of the siphon tube and I go back to blasting. Since it's not bolted down, I can move it to where the sand winds up, or use it to scrape what's clinging to the sides back to the bottom. Waiting for the compressor to catch up (or giving it a quick break) is a good time for this! Works super.
To keep everything simple, I duck tape the glass on, and change it OFTEN, rather than an elaborate frame. I use a bungee cord to keep the door closed. Used my bathroom flourescent light fixture (didn't like it there). Simple stuff like that.
I've used really nice blasters in military auto hobby shops and mine works better. The trick seems to be keeping clear glass and being able to remove clogs EASY. When I run up on a piece too long, I'm going to get my saber saw and cut a hole in the side, slide in what I can and seal around it with tape and plastic. When I'm done, going to drywall screw the plug back in place.
Bought gloves from Eastwood, $20. Used EXACTLY 3 sheets of surplus plywood.
In all honesty, here's the drawbacks. A trigger gun IN a cabinet is so-so. Could buy a foot switch and triggerless gun from Eastwoos, TP, someone like that. Don't have safety glass, so I'm careful.
Have fun,
Mike
