Tool Talk Discussion Forum
Try this
Welding Rep
10-01-2005 18:11:11
PRE-WELD PREPARATION:
The ground cable should be firmly attached to the workpiece.
Position the workpiece in secure and stable manner.
It is preferable to position the work piece so that
welding will be done in the flat position with the electrode
held vertical. The welder should insure that a comfortable
and balanced position can be maintained during
the procedure.
STUD PULLING PROCEDURE
FLAT POSITION:
1. Figure 1 is a cross section of a housing showing a stud broken off
below the surface of the component.
2. As shown in Figure 1, place the Cronaweld 333 electrode in the
center of the threaded hole, keeping the electrode perpendicular, and
strike an arc on the center of the broken stud. Avoid tilting the
electrode so as not to arc on the threads.
3. While maintaining a short arc, use a slight circular motion (not to
exceed 2 times the diameter of the electrode) and fill the hole with
weld deposit. As the electrode burns off, the flux will form a protective
barrier between the weld deposit and the threads.
4. Continue the procedure to build-up a column of weld metal until
it reaches the surface of the housing as shown in Figure 2. Break
the arc by lifting the Cronaweld 333 electrode straight up. Do not
allow the weld deposit to roll over onto the housing surface.
5. Chip the slag away from the top of the weld deposit and place a
washer (used for spacing) and a nut over the deposit as shown in
Figure 3. The nut should be approximately equal to the diameter
of the broken stud.
6. Weld the nut to the Cronaweld 333 deposit, completely filling
the inside of the nut with weld metal.
7. Allow the stud, Cronaweld 333 deposit and welded nut to completely
cool to room temperature. DO NOT QUENCH.
8. Using a hand wrench, remove the broken stud as shown in
Figure 4.
9. After the broken stud is removed, chase the threads with the
proper size tap to remove any remaining slag and to clean up the
threads.
OUT OF POSITION APPLICATIONS:
Use the same procedure as for flat applications, with the following
exceptions:
1. Amperage settings for removal of broken studs overhead might
need to be reduced approximately 10% from the settings for flat
position applications.
2. A continuous arc and build-up may not be possible. The build-up
can be obtained with short intermittent welds, making sure to hold
the electrode vertical so as not to arc on the threads.
