Tool Talk Discussion Forum
Welding ?
Stan(VA).
09-29-2005 07:27:37
I have heard people talk about an option for getting out a broken off bolt by welding a nut on the stud left sticking out. I have a radiator support brace with a broken 5/16" bolt that has a little thread sticking out on the inside edge (outside broken flush). I tried to weld a nut on the stud this morning and I'm not getting anywhere so thought I'd ask for any suggestions. First try, the nut got cherry red and filled quick, but just fell off (no penetration to the stud), 2nd time I heated with a propane torch, then concentrated weld on the stud first and then opened up to the nut. That time the nut held enough to put a wrench on it, but the nut twisted off before the stud moved.
I have a century AC/DC buzz box that I used at ~40Amps DC rev, on a 1/16" 6013 rod (not any science setting it up, just the way I used it last!). I am obviously just a beginner welder. Any suggestions, or should I just go to the drill press and start messing with the (now hardened) stud?
Thanks,
Stan(VA).
Welding Rep
10-01-2005 18:11:11
 Try this in reply to Stan(VA)., 09-29-2005 07:27:37
PRE-WELD PREPARATION:
The ground cable should be firmly attached to the workpiece.
Position the workpiece in secure and stable manner.
It is preferable to position the work piece so that
welding will be done in the flat position with the electrode
held vertical. The welder should insure that a comfortable
and balanced position can be maintained during
the procedure.
STUD PULLING PROCEDURE
FLAT POSITION:
1. Figure 1 is a cross section of a housing showing a stud broken off
below the surface of the component.
2. As shown in Figure 1, place the Cronaweld 333 electrode in the
center of the threaded hole, keeping the electrode perpendicular, and
strike an arc on the center of the broken stud. Avoid tilting the
electrode so as not to arc on the threads.
3. While maintaining a short arc, use a slight circular motion (not to
exceed 2 times the diameter of the electrode) and fill the hole with
weld deposit. As the electrode burns off, the flux will form a protective
barrier between the weld deposit and the threads.
4. Continue the procedure to build-up a column of weld metal until
it reaches the surface of the housing as shown in Figure 2. Break
the arc by lifting the Cronaweld 333 electrode straight up. Do not
allow the weld deposit to roll over onto the housing surface.
5. Chip the slag away from the top of the weld deposit and place a
washer (used for spacing) and a nut over the deposit as shown in
Figure 3. The nut should be approximately equal to the diameter
of the broken stud.
6. Weld the nut to the Cronaweld 333 deposit, completely filling
the inside of the nut with weld metal.
7. Allow the stud, Cronaweld 333 deposit and welded nut to completely
cool to room temperature. DO NOT QUENCH.
8. Using a hand wrench, remove the broken stud as shown in
Figure 4.
9. After the broken stud is removed, chase the threads with the
proper size tap to remove any remaining slag and to clean up the
threads.
OUT OF POSITION APPLICATIONS:
Use the same procedure as for flat applications, with the following
exceptions:
1. Amperage settings for removal of broken studs overhead might
need to be reduced approximately 10% from the settings for flat
position applications.
2. A continuous arc and build-up may not be possible. The build-up
can be obtained with short intermittent welds, making sure to hold
the electrode vertical so as not to arc on the threads.
jfp
09-30-2005 05:33:00
 Re: Welding ? in reply to Stan(VA)., 09-29-2005 07:27:37
I never use easyouts. I use reverse drill bits from the hardware store. They never fail when used correctly.
dr.sportster
09-29-2005 13:43:41
Took me 8 tries with the nut Tigged on last time I did this.I meean it broke 7 times before unscrewing.Grind the coating off the nut a little maybe or wire wheel the heck out of it first.I never had luck with an easy out but the left hand drill bits have pleasantly surprised me on small broken bolts.Sears has a solid carbide burr for the Dremel tool if it gets messy,Good Luck it feels good when it comes out.
sawtooth
09-29-2005 12:07:47
It depends on the situation but sometimes I've been able to use a hand grinder with a small diameter cut off wheel and grind a slot in the end of the broken off bolt. That means you're also cutting into whatever is around the bolt. If it doesn't matter, after slotting you can use a heavy duty square shank screw driver with a wrench on the shank.
Bob
09-29-2005 08:05:41
Weld a flat washer to the stud first. That will allow the arc to reach the broken stud better than trying to weld through the thick nut, and fuse the weld to it. Then, either simply grip the flat washer with a Vice-Grip, and unscrew the stud, or weld a nut to the top of the flat washer.
As the part cools down to a safe level, but is still warm, spray some Thunderbolt or PB Blaster on the thread area.
The secret is to let the part cool completely down to ambient temperature, before even trying to "wrench" on it. The thermal cycling of heat (from the weld), and cooling down helps to break the stud loose.
If the weld breaks loose, repeat the whole procedure. Often, and extra thermal cycle will break things loose.
Stan(VA).
09-29-2005 12:43:35
 Re: Welding ? in reply to Bob, 09-29-2005 08:05:41
Thanks to all that responded. I have had to deal with busted off easyouts (and taps) before in small holes, and wanted to avoid that if possible.
Bob,
The washer method worked. All I could find was a lock washer which I burned through on one side. So the weld wasn't pretty but had enough for me to grab with a vice grip and I was able to get it out.
Thanks for the help,
Stan(VA).
mechman
09-29-2005 09:29:17
third party image
wouldn't an EZ-OUT be better than firing up the welder?
lucasss
09-29-2005 14:28:34
 Re: Welding ? in reply to mechman, 09-29-2005 09:29:17
i use those spiral easyouts to remove oil galley plugs in engine blocks .they work great... but i agree they arent to good on rusted seized threads. lucas
old
09-29-2005 12:34:59
That type of E-Z out you can't pay me to use. The one I have had like that got put in to a bunch or scrap iron I sold a couple years ago. In my book those are just plain trouble. I have a set of E-Z out that do wirk well and will not brake like those junk one do. Also you never have to use a hammer on the type I use.
ebbsspeed
09-29-2005 11:09:25
EZ-Outs are OK if the bolt is broken off due to being sheared off, but if it was twisted off due to rusted/siezed threads, best leave the EZ-Outs in the drawer and use some other method.
Illinois Boy
09-29-2005 09:42:45
Ouch - I hate those things... If you break one of those off - well, I'll let someone else remark on that - I don't want to recall the LAST time I used one. (I'm finally calmed down and don't want to get all fired up again!!)
RustyFarmall
09-29-2005 14:02:14
 Re: Welding ? in reply to Illinois Boy, 09-29-2005 09:42:45
Good to hear that I am not the only one that has no luck with those things. The truth is that I have tried them several times, and have NEVER been successful.
mechman
10-01-2005 18:16:48
 Re: Welding ? in reply to RustyFarmall, 09-29-2005 14:02:14
i can understand not using an ez out on a rusted or seized bolt. makes sense to me. stan just mentioned in his post it was broken, not rusted.lots of good info here.
