Tool Talk Discussion Forum
Go for it
LeMaveick
09-09-2005 15:50:08
Larry, that is a great little grinder. I set the "shelf" angle to match the original grind on the planer knives, then hold the knife against the shelf with fingers of one hand and move the blade across the stone with the other hand (and switch half way). Keeping the grind uniform wasn't any problem.
If it works well for you let us know so others will be encouraged to try. (Course, if it doesn't work don't say anything -- hehehehe -- JK). If I can do it you can do it and if you and I can, anybody should be able to. Right?
