Tool Talk Discussion Forum
Long Post.
Keith-OR
09-05-2005 07:03:04
Take it down, Get yourself a Sawzall, use bi-metel to cut all nails. That size of building in my area would be double trusses, one on each side of the poles. They should have bolts going clear through both trusses with braces nail under each one. Get yourself 4-6 inch pieces of tubing that will side over the poles, weld an end plate on each one, making a pole cap. Then bolt or weld a handcrank boat winch to each tubing cap. These can be used to slide trusses down the poles. Hopefully they screwed the sheet metel on,best way to remove sheet metel is buy yourself a GOOD cordless drill with couple extra batteries. Having one in the charger at all times.The very best way to take a pole building down is in the EXACT opposite way it was put up...BEST OF LUCK..Keith
PS email me on details on taking down trusses.
Like to see that
09-05-2005 09:03:30
 Re: Long Post. in reply to Keith-OR, 09-05-2005 07:03:04
Keith, Have you ever tried sawing pole barn nails with a sawzall?I have and they are hardened nails.I never had any luck sawing the darned things.Burned up or broke a lot of blades though.
Keith-OR
09-05-2005 11:46:25
 Re: Long Post. in reply to Like to see that, 09-05-2005 09:03:30
Cut lots of pallet nails which are extremely hard plus they are screw nails for hard wood pallets. You just have to buy real good saw blades, NOT CHEAP ones. You ever try to take pallets a part without cuting nails you just break the boards. I use Sawzall in remodeling, greatest tool for removing studs, top and bottom plates or any place there is a blind nail or screws. Trick is to buy different Bi-metel blades untill you get the right combination for your job..HTH..Keith
Chances R
09-05-2005 11:21:02
third party image
You know I thought the same thing until the other day. I cut through about 10' of some wood and about 50large nails in less than 5 minutes the other day with 1 blade. Yep I was impressed.
